analog addict
Glory or Death!
After I measured the DC offset on my "new" Hafler Dh-500, I found that the left channel was ~100 mV and the right was ~500 mV. Ouch.:worried:
I did some searching and reading, and apparently according to the manual, it takes 1.8 VDC to trigger the protection relay. I also found out that the 500 had three variations of PC-19 board, and only one of them the newest, had a pot for DC offset adjustment. IIRC, this board was supposed to have two pots one for DC offset, and the other for bias....Here's the picture of my board(s)...
I only see the one black pot in the middle of the board. Can I rightly assume that this is the bias pot, and I don't want to be screwing around with it? If so, what else can I do to adjust the DC offset? Anything? Do I even need to worry about it? My intention for this amp is to run prolly the bottom end of my RSIIb's, and use another amp for the top end. Does this sound reasonable? I have tried this amp as is, and it sounds fine....
