Wigwam Jones
Caesar non supra grammati
I took everybody's advice and simply refoamed my Realistic Nova 5 8-inch woofers instead of replacing them. That's all done now and they sound pretty good. However, the tiny, tinny, 2 1/2 inch cone tweeters have got to go. They sound like poop.
I have a set of Foster horn tweeters I picked up cheap; part number 49-1166, marked 74.24 (I believe this means they were made in 1974) Japan Zenith Radio Corp, Chicago, IL. Supposedly came out of a set of Zenith Allegro speakers.
I did a trial fit, and darned if the things don't *almost* fit into the existing tweeter holes! A little work with a rasp ought to get them in there nicely. Plenty of room inside the cabinet for the back of the horns, no problem there.
They actually sound pretty darned good from what I can tell hooking them up outside the box. Bright and clear. The cabinet still has the standard 4.7 uf capacitor crossover in it with some kind of resister - can't quite read the value - in series with the capacitor.
Any thoughts on whether or not this would be a good match? If not, what would you recommend? Anything cheap - and anything that is NOT the stock tweeters, they suck.
Thanks!
Thanks!
