It's only a small nitpick:
There've been some very nicely done youtube videos recently claiming that before the 1971 1000 ZE/X family, Empire was still making moving-magnet cartridges. This is demonstrably not the case. Grab a pre-1971 stylus; point it straight up. Straighten a household staple or other fine steel wire, poke it gently upward into the brass tube until it stops. Let go and it will simply fall right back out, as it does in my ca. 1965 888 PE's stylus. The "magnetic cone" is mumetal, soft iron, permalloy: magnetic but not a magnet.
However, a moving-magnet stylus can be made to work in a variable-reluctance body, as Ortofon has done in my VMS 5E Mk II and OM 5E. As far as I know, Empire never did.
