That's an impressive needle collection. I've been collecting needles like those since around 2018 but only have maybe half of that. The needle in the first picture looks more like an 888SE needle (232-sde). There was a lower-priced special-value-version of the 888-SE released in 1967 or so, and it featured that black grip and purple lettering as seen in the picture versus the usual light blue grip. Should be a .3x.7 bonded elliptical diamond. I was given a used one on its original 888SE body with black plastic mounting bracket years ago. The needle was quite worn but it has a straight cantilever and still plays well despite sagging quite a bit. It was that hard-hitting, dynamic high-output sound that got me hooked on these old Empires in the beginning. There is a link somewhere in this thread to an old magazine ad showing the special value 888SE and maybe the 808E as well.Found what looks to be a branded s8087rd needle recently. The cantilever has a kink but she's very pretty and plays well! I'm quite surprised at how tapered the cantilever is for a conical.
Side note, I have been collecting empires over the last 1.5 years or so. They are still quite available with some hunting. The needle is picture above my empire stack. I didn't have any of these 2 years ago. If anyone would like some detailed pics, I'll do my best without opening packages. View attachment 3709011View attachment 3709012View attachment 3709014View attachment 3709015
The 2000E and 2000X bodies are electrically different, but it's one of those "if you can hear it with your system, it may or may not be important to you, because the difference is in the top two octaves (~5kHz to 20kHz) of the audio spectrum" things. But as Jeannot points out, mechanically there's no difference. You can do the "pop and swap" with impunity.So going back to your 2000X discussion. As I look more into its replacement stylus and reading the ohms is about 450.
Can I use the similar shank 2000E III stylus .3 x .7 diamond elliptical? with the preamp settings of 47k Load and 45 db Gain?
Wiser words were never spoken..........and you may just find your own "Lost Chord"Don't be afraid to try any combination that presents itself. There are differences that are significant.. and then there are all the other differences. The top octaves-- indeed the whole spectrum-- can be manipulated in many ways, especially now.
Thank You...Apologies for missing this until now:
I will post you a report and thank you much again!If you do try some "wrong" combination(s), let us know if you hear the difference, and if so, whether that difference is important to you, either as a tweak or a defect.
Going back to the Gary 4329-DET. So basically all the colors of silver, gold and trans amber are all built and pretty much sounds the same?The Silver one is (like) new, sounds fantastic, I swapped out the Silver to the Translucent Yellow and playing the same album is again fantastic! Three styli, this should last me a long time. I owe you a beer, you discovered the clone. Thanks a ton!
Edit/Update: I had a major blow out with my Translucent Yellow stylus, it refused to come out of the cartridge body. The plastic front separated from the shaft, the shaft was extremely tight fitting and the two came apart. Sadly this once great sounding stylus is no more. The cantilever broke off and the shaft had to be extracted with pliers and collapsed/crushed at the nose when attempting to get a 'grip' on it.
All this happened from me getting an arm/wand from one of the Harman Kardon ST-7 tables I own, this one was my parts table that I decided to sell off to a fellow AK member here for his need to repair one or two of his own tables he had bought but unable to use do to very careless Ebay sellers very poor packing efforts.
Trying to help him out I cost myself this stylus. In hind site it would have likely happened anyway because it refused to come out "peacefully". I will be ordering another from Gary at TVOM again but this next time will stick to the Silver one, this is the original color and it's snug but not ridiculously tight like the Yellow one.
That's been my experience and was the test result of the German magazine HiFi Stereophonie in the March 1978 issue (2000Z and blue 2000T). But let's hear from others. There are always variations in production, especially after 50 years.Going back to the Gary 4329-DET. So basically all the colors of silver, gold and trans amber are all built and pretty much sounds the same? Thanks...
Thanks...
Let us know if you hear a difference.
When testing a DIY damper, you can mount a heavy-but-hypercompliant cartridge like ADC's 10E Mk IV and watch for cantilever movement relative to the cartridge body when playing a record with a mild warp. Another way of checking is to use ported speakers, turn off any "rumble" filter, and watch for woofer wobble that indicates the speaker's trying (and failing) to reproduce infrasonic bass.
Thank you for the info and tips once again! I had a 792-D7 on hand and it does fit perfectly. The back of the package states the 792-D7 replaces Marantz ct-300, Toshiba n-292, hh scott 20sc, and Sharp sty-127. I'll give the 246 a try on the Oyster when I can find one.I don't have the 140C/245E cartridge as such, but I do have a variant (no gold on the pins) of your silver-bodied clone, which was sold under several names, but mine was claimed to be a Marantz, and it is, with several names for the same cartridge+stylus. I decided mine is a CT-300 with a conical 792-D7 stylus. It's also a Sharp, Toshiba, Teledyne and Unitra, along with an IM variant branded as Omega. I have no idea which Japanese OEM made it.
I recommend the ruby red 246-DEX nude elliptical for your Oyster even though there's an inductance mismatch that will elevate the high treble. Tracks at 1.25g.
