Dennon DP-300, Pro-Ject Debut III, or the Music-Hall 2.1. I'm gonna say the REGA is probobly not in the Budget as these are all $300 +/- tables...
Well mnrider, I've owned all 3 so lets look at it this way:
Pro-Ject and Music-Hall are basialy the same table just different arms and names. However, the Pro-Ject DEBUT III is a cut above the Music-Hall I feel and with the addition of the SpeedBox, you can really get AMAZING performance from the DEBUT III. AWESOME performance!
The Denon DP-300 is a whole different beast from the Pro-Ject and Music-Hall. Priamaraly made of plastic but in all fairness, it does have a good tonearm on it. The Denon does sound quite good when fitted with an AT440MLa and if you want a fully auto deck, the Denon is the way to go!
Now...If you are more interested in performance and expandability, I would go for the Pro-Ject DEBUT III and maybe down the road, add the SpeedBox. If you want convienience and ease of use, go with the Dennon. With any of these tables, you really need to upgrade the cratridge. For the Denon, I recomend the AT440MLa, for the Pro-Ject, the LP Gear AT95SA.
So, Full AUTO, get the Denon. Performance, get the Pro-Ject.
Hope this helps,
Joey1127
