SX-850 FM Problem
tsd71
RIP Tom Petty
i have an sx-850 that is real nice, am sounds great, aux great,phono great, but no fm...i recapped the tuner board but to no avail, still no fm, both meters work perfectly and tune to stations, but no audio, just a faint static and a small sliver of audio when volume is turned all the way up...what next...could the pioneer chip be bad (HA1137 6F3) that is on the board? everything else works great and sounds awesome...also i have done the de-oxit routine twice...thanks...goin to moms for dinner will return later!!
Welcome to the new thread!!
We want to see if the FM detector chip (HA1137, pin 6 out) is making audio, and if the stereo decoder (HA1196 pin 2 in, pins 6 & 7 out) is working. After that we check out the muting circuit, which actually reads the lamp circuit's ac just like the protection circuit !!!!
The 850 has a jack on the back called FM det(detector) out, that an rca cable can be used to cross connect it to a tape monitor input (leave the function select at tuner so the tuner gets all it's power ) to see if the FM detector chip (HA1137, pin 6 out) is really making audio. neat huh?
p.s the 1138 is the AM tuner
Next would be to take an interconnect cable, and connect one lead of a 0.1uf 50 to 100( or higher) volt ceramic disk (or other non-polarized cap from 0.01uf on up) capacitor to the center contact. The other leg of the cap is your probe. It won't be hifi, but it will detect the presence of audio.
Leave it connected to the tape monitor in, so we have working volume control, and then touch the cap leg / probe to the HA1196 pin 2 to test the audio input and pins 6 & 7 to test the left and right channel outputs.
If we are lucky you will hear audio on all 3. That means the muting circuit will need voltage readings taken. That calls for the DMM.
attachment.php
I've used a probe hooked to the input of an outboard amp to trace signals for years, but I never made the leap to just use the Det. out back to the tape monitor of the receiver under repair. Good idea.
Now back to our regular program.
mark, on this unit after doing the fm out to tape in i have fm but not stereo, then using the probe technique i am getting audio out of pin 2 but nothing out of pin 6 or 7 of the HA1196...man am i having bad luck or what lately.....whats next...as always thanks
mark, after taking readings , probing and so on , i am getting basically nothing out of the ha1196 chip(voltage readings) now, after examining the board i noticed that at C42(styrol 510p 50v) the cap looks bad like it was overheated, the casing looks like it wants to pop off...now could this be causing ha1196 to be misbehaving? i know i have access to the ha1196 from mouser nte1484, but what is the reference number for the styrol cap C42 if that might be the culprit, i've already recapped the rest of the board
mark, i'm going to order the ha1196, do you think C42 has any bearing on why i'm having this problem
I don't want to offend, but did it work before? There are NO voltages? What are the dc voltages on the pins, especially pin 1 which is power... that is important...
re: the cap
wow talk about a can of worms.... it is a radial leaded cap, and the value ranges available are all axial leaded now. and it is a 510 pf... standard values are 470 and 560 at 5% tolerance... but if you get a 180 and a 330 and parallel them you do get 510...
for right now though, C43 and C44 are exactly the same, in a non-critical portion of the circuit... you can swap one of them in to try to get the 1196 going, that cap is the main cap for the VCO, sort of a critical part...
The donor part will just eliminate the de-emphasis curve on one of the stereo channels. and the value in that donor's spot is far less critical. There will just be a difference in the "brightness" of one channel until corrected.
These Styrol / polystyrene caps are EXTREMELY heat sensitive to damage.. you MUST heat sink the leads while soldering or desoldring.
Styrol / polystyrene caps are very temperature stable as to their capacitance value, which is why they are used.
mouser.com
23ps118 $0.24 180pf
23ps133 $0.22 330pf
23ps147 $0.22 470pf
23ps156 $0.22 560pf
worse comes to worst, I have ONE radial leaded 510 pf cap from an old stripped receiver.
edit:
Yes... see above, but check for power at pin 1 first, that part is a bit expensive....
mark, i took the voltages last night at work,pin 1 was coming in if i remember correctly .0350v...all the other pins were weird readings too, when i get into work tonight i will post the readings..i received the unit without the fm section working...also how do i heatsink the leads for the swap
Pin one is the MAIN POWER, and it should be around 12.8 volts.... without it nothing works, and there are a LOT of things to check before messing with that cap. C34 could have shorted and popped R34 for example.
ordering parts right now won't matter until late sunday night, it's all the same....
And since you don't have it in front of you, I will take my time to get it RIGHT over the next hour or so to map out points in the power stream for you to test to see where it gets lost. THEN I will post it. Since you posted at 4am I thought I could do this post without rushing, get it right without somebody jumping on a partial post, as I WAS going to address the power issue.
Did you ever test the AM to see if IT works.... it is part of the power issue.....
Nevermind, audio at pin 2 makes the R34 popping because of C34 shorting much more likely.
If you can, try to get a picture of that "C42(styrol 510p 50v) the cap looks bad like it was overheated"...... it might not be bad... it's a strange looking cap... I'll try to post a picture in a while too...
yes mark the am works perfectly, as does the aux and phono,also as i said before after doing the fm out to tape in i have fm but not stereo, then using the probe technique i am getting audio out of pin 2 but nothing out of pin 6 or 7 of the HA1196...i get into work at 11:00pm est, so if you post i will check everything when i get in tonight, and report back
mark, there are 3 of the styrol caps and this one looks different than the others,the others are short and you can see the leads, this one looks like the outer shell is elongated, like its trying to come off, i'll take a pic tonight and upload
also i have extra caps from the original recap so i have an extra C34, what is the value of R34 it says 10 in the manual, would that be 10ohm 1/4 watt?
Yes, that would be it...
here's the cap:
attachment.php
ok mark, that is what i thought the bad one looked like, the other two which are the same values look shorter and you can't see that lower part the yellowish part with the leads attached...why do they look different if they are the same exact cap
anyway i'm assuming if it looks like your picture it ok, should i go and replace the
C34 & R34
C34 & R34
You need to read the voltages (referenced to ground) on both sides of R34 before doing anything. One side has to be 13v and the other should also be 13v. If not, yes, replace them both, then ohms test the old parts out of circuit.
Until you get 12.8 v or so on Pin 1 of the ha1196, nothing can be expected to work.
ok mark these seem very strange
1- .210v
2- .025v
3- .175v
4- .205v
5- .205v
6- .200v
7- .200v
8- gnd
9- 13.81v
10- .003v
11- .004v
12- .675v
13- .003v
14- .004v
15- .004v
16- .000v
1- .210v 9
2- .025v 10
3- .175v 11
4- .205v 12
5- .205v 13
6- .200v 14
7- .200v 15
8- gnd 16
9- 13.81v 1
10- .003v 2
11- .004v 3
12- .675v 4
13- .003v 5
14- .004v 6
15- .004v 7
16- .000v 8
The upper left corner that is either notched or has a dot off centered at a corner pin is one. The diagram and the foil pattern are both drawn to facilitate access from below.
I think the revised list above is my best guess of what you read.
