Welcome to the new thread!!
We want to see if the FM detector chip (HA1137, pin 6 out) is making audio, and if the stereo decoder (HA1196 pin 2 in, pins 6 & 7 out) is working. After that we check out the muting circuit, which actually reads the lamp circuit's ac just like the protection circuit !!!!
The 850 has a jack on the back called FM det(detector) out, that an rca cable can be used to cross connect it to a tape monitor input (leave the function select at tuner so the tuner gets all it's power ) to see if the FM detector chip (HA1137, pin 6 out) is really making audio. neat huh?
p.s the 1138 is the AM tuner
Next would be to take an interconnect cable, and connect one lead of a 0.1uf 50 to 100( or higher) volt ceramic disk (or other non-polarized cap from 0.01uf on up) capacitor to the
center contact. The other leg of the cap is your probe. It won't be hifi, but it will detect the presence of audio.
Leave it connected to the tape monitor in, so we have
working volume control, and then touch the cap leg / probe to the HA1196 pin 2 to test the audio input and pins 6 & 7 to test the left and right channel outputs.
If we are lucky you will hear audio on all 3. That means the muting circuit will need voltage readings taken. That calls for the DMM.
