SX-850 FM Problem
Fm was selected,antenna was connected, and the mute is turned off...
no fm from the speakers
pin 1 does not have 13 volts
pin 2 has audio pins 4 & 5 do not
all readings are mostly the same for all the pins on the chip...still have `13V at pin 9
R34 13V both sides
R33 0.415V both sides
R32 0.415V both sides
C34 0.415V pos 0.000V neg
Good readings by the way, it's not your fault they are bupkus....
Doesn't this make you suspicious? One lead from EACH of these components should all be connected together to this ONE pc board trace.....
Ok, no power for these tests:
connect one lead of an ohmmeter to the plus side of C34, then test for zero ohms to one lead each of R32, R33 and the ha1196's pin 1. There should be... Then with the same reasoning, one side of R34 should ALSO have zero ohms to C34's plus side. It WON'T...
I am assuming that you got a good solder connection when you installed the replacement R34, so then the only possible explanation is that there is a hairline fracture across the pc board's trace somewhere between R34 and the other components it is SUPPOSED to be connected to.
The break HAS to be in the long "squiggly" portion between the R34 lead and C34's positive lead.
Rather than searching for it under the solder mask (the green coating), connect a wire (insulated) between R34's connection and C34's positive connection, running it over and parallel to the suspect trace.
If you are confident of your soldering skills and think you can do this without burning up the trace, (and you have a controlled temperature iron) the procedure would be to scrape the suspect trace down to the bare copper, tin the trace and solder a BARE wire to the trace from component joint to component joint, ensuring a good connection, somewhere along the way the bare wire will bridge the gap.
I shouldn't have rejected the possibilities of this earlier, I fell victim to the fundamental theorm of information engineering, the more improbable the data, the more important it is, and I attributed two weird readings as erronious, when they were stone cold solid good.... sorry.... took us on long jaunts about ic pin orientation (because of the 13.8v from the stereo lamp), shorted caps, blown resistors or bad chips pulling too much current (but then, where's the HEAT??? from all that shorted energy...) and all that....
Like I have said before, once we get 13v on that pin one, THEN we are cookin.....
mark, guess what i'm listening to.... the beautiful sounds of fm stereo right now with no issues....i took your advice and connected a wire between R34's connection and C34's positive connection, running it over and parallel to the suspect trace.i then put it all back together and flipped the switch and now i'm in fm heaven...i've said it before "you are the man"...here's the latest readings from ha1196
1 13V
2 3.2V
3 8.3V
4 10.6V
5 10.6V
6 6.2V
7 5.9V
8 Gnd
9 13V
10 .062V
11 2.4V
12 .692V
13 2.3V
14 2.5V
15 2.5V
16 3.2V
some of the numbers on the backside 9-16 seem a little off the manual specs is this a problem?
again, i can't thank you enough for the time and effort you put in to help not only me but many others on this site...
i still have the 1250 sitting in my garage i will pack it up and get it out one of these days...
one question on that sx-1250 how do you test to see if the transformer is bad
thanks again mark
Testing transformers is tricky and there are a lot of procedures...
luckily they are robust devices..... I do know of some that they wind a thermal fuse inside to prevent fires from massive overheating, if that guy is popped, it's curtains.... because it's buried and it interrupts the primary winding.
on top of that the 1250 schematic does not show one...
and finally, with the way some vultures are parting them out on fleabay, it won't be hard to find one IF we need it.... beause nobody usually does need it unless they are changing to a different voltage or multi voltage primary....
