no thats a lifted picture, i forgot to bring my camera to work, i thought about the chip being backwards...but i hope i'm not crazy or dumb, but if you look at the owners manual page 18 the colored picture of the foil side of the board, would you not concur that the way i notated the pin numbers on the picture i attached coincide with the graphic form the manual, with pin 1 being close to wire wrap pin 19, that pin 1 is getting me the .210v reading, so if you look at the graphic in the manual it isn't making sense...could the chip be backwards...but why then did i get audio from pin 2 with the probe earlier..........maybe i should stay with computers
That audio is being FED TO pin 2, it is an input.
And, yes, the numbers you added to the image you posted ARE CORRECT, which leaves the voltage readings much more puzzling.
The pin 1 of the ha1136 should have 13.8v or so, there are three resistors and a capacitor ALSO connected to that foil, which will SPECIFICALLY identify it without a doubt:
r32, 30k orange black orange gold, with the other side of the resistor going to pin 4 of the ic
r33, 30k orange black orange gold, with the other side of the resistor going to pin 5 of the ic
r34, 10 ohms, brown black black gold, with the other side being fed +13.8v
c34 47uf , with the other side (negative) going to ground.
So I don't know what you measured when you said that there were 13.8v on BOTH sides of R34. R34 is adjacent to wire wrap pin 22 going off the board, with a capacitor C32, 1uf 50v between r34 and wire-wrap pin 22. On the other side of r34 is a pot. r34 is the only resistor in the vicinity elevated in the air with fabric sleeves insulating the leads in the picture....
The 13.8v on pin 9, would then be the stereo indicator light, which IS correct, that pin has to be pulled to zero volts (0.8v actually) to light the lamp.
So, we still have a power problem on pin 1. if the resistor is ok, check all the solder joints on that pad.
