Do all P-Mount cartridges weigh the same? If not, can the arm on a linear tracking TT be adjusted for the wight difference?
Thanks
Bart
The T4P standard was 6g, with a tracking force of 1.25g. P-mount tables without any adjustment are set for that weight and TF. AT and Shure adhered to the T4P standard. You take your chances with Ortofon and Grado, not only with the weight, but with the required tracking force. If the tt has fully adjustable TF, it's not an issue.Do all P-Mount cartridges weigh the same? If not, can the arm on a linear tracking TT be adjusted for the wight difference?
Thanks
Bart
Thanks
Bart
5.9g wouldn't be a big deal. The Grados weigh 5.5g and require 1.5g TF. So if you have a non-adjustable tt that is expecting a cartridge weighing 6g and tracking at 1.25g, your effective tracking force will be .75g, half of what is required by the Grado.they do not weigh the same, although they should.
there are some that weigh 6 grams.
and then there are some that weigh 5.9 grams.
Yes, I should have mentioned Pickering/Stanton. And good to know about the Grado. Just too bad mfrs don't publish accurate specs.My Grado Silver p-mount does weigh 6 grams, but I have the ability for adjustment on my Technics SL-M3 (linear tracker) and SL-MA1 (pivot arm) to bump up the tracking force to the suggested 1.5 grams.
I also have some cheaper Technics models that don't have the ability to adjust the tracking force. I used an SL-BD22 for many years with a Pickering TL series cartridge (6 grams even) with good results; I'd put Pickering/Stanton in with the reliable manufacturers of T4P cartridges.
Do NOT buy grado for p-mount . I did some time ago...I suffered enough...
Some P-mount TTs offer an adjustment for tracking force, although even those "better" ones have this adjustment burried in the mechanism. The two TTs that come to mind offering VTF adjustment are the Technics SL-M3 and the Dual LT-100.
If the cartridge doesn't have a T4P logo on it, it deviates from standard.
I'd say that if it has the T4P logo, it meets Technics' original standard, but if it lacks the logo, it wasn't certified to meet the standard but still might.
No, you can't go by that--it wasn't always on the body. In fact, I don't remember any Shures that said T4P on the bodies or styli.Inclined to agree, as it's being used the AT92-ECD seems to fit the standard specifications correctly yet it has no T4P markings.
