Hello everybody!
Summer is here and I have a goal- to learn to desolder/solder caps so I can fix up my 2215B, 2230, and eventually the imposing 2270. First things first, I would like to start on the significantly simpler looking 2215B and use this as a learning experience so I can eventually get the other guys done too.
Here is what I need help with- Getting the new parts. From where should I get a list of the required parts, should I just read each of the parts to replace from the 2215B here or does a list exist elsewhere? Then, from where should I buy the parts? Are there some parts that I need to worry about fitting differently like the bigger caps?
Essentially starting from scratch, but I really want to get this done- I already have the tools (solder gun, rosin, solder wick, desolder bulb, multimeter), and I have the space to do it.
Any help would be greatly appreciated, and I will take pictures should they be required as I go through the process. Thanks to all, here is to summer projects!
