jstang
Honey,I can't hear you...
Space, money and time.....
Film caps will be larger and more expensive than the typical same spec Electrolytic.
These are the two best reads on audio caps that I have found...
http://web.archive.org/web/20030807122631/http://capacitors.com/picking_capacitors/pickcap.htm
http://members.aol.com/sbench102/caps.html
read up.... and lets chat....otherwise its a recommendation without meaning. But the Tantalums than cheapy electrolytics are the lowest on the food chain....but sometime you have no choice and sometimes it does not matter..... You can greatly improve some caps by putting a .1 film cap in parallel. That is usually easy to fit in the same space.
Film cap are almost always going to last longer.....and sound better.
jk
jk
