Thanks for the info! Mine is also a nippon chemi-com 50v 100uF. Do you plan to replace it with the service manual spec 220uF or stick with the 100uF that was put in our units? I plan to do all boards (even that nasty p100 tuner) and be done with it- I'm sure I'll work on the power supply (p800) or p700 first and move on from there. Did you say you replaced the output transistors too? Cool that we appear to be working on this at the same time, feel free to contact me with questions and expect a few from me laterMine is a nippon michi-con (now called nichicon) 100uF 50v 11mm dia x 20mm L, you can go up to a 250uF if you want just make sure it is 50v and watch the size. Which boards are you doing? I started on my 700 board and Got got 4 caps done and all of the output trannies/bias. Gotta wait for my mouser shipment for the rest. I went all Nichicon because I couldnt find any place that had al the Elna's in stock.
Oh, and whats special about elnas? I have looked at digikey and I guess I'll go for the panasonic FM series as first choice followed by nichicon HE.hmm- I was thinking that at first, since this will never be used for its tuner, however I thought it might be worth it to just do it all. Maybe you are right.Elna makes the Cerafine, which are supposed to be pretty good caps. With shipping at most sites around $6-8 I wanted to one stop shop. As in my earlier post, I have a collection of a few 2216 and 2215B's. i buy them with blown amps and recap/tranny em. The project I am working on is for a spare.
Now recapping the 700 and 800 is ok as well as the electrolytics on the tone board, but I would stay out of the tuner unless you have the gear to recalibrate it.
the film caps are way too big it seems, I am not gonna even try to fit those in. I will have my complete list soon!Tantulum capacitors are rather nice and are in small packages. They can be darn expensive though. I went with Kemet (name brand) but you can use vishay are any others. Just make sure they are radial dipped and not SMD (surface mount). You can find some film caps and use single sockets on the board. This way you can swap the film in for the tantulum on the 700 board, just pay attention to the size. most poly film are humongous and are rated at 250-1000v for use as snubbers and filter caps. The holes on the board are only 3mm apart.
20,25v tops? I do not know what is safe here.Go higher in voltage stay close to 5mm diam by 12mm length because CE15 sits right against RE33. You can get whatever is available like 20v, 25v, etc. Worst case get a tantalum.
cool! There is a 50v panasonic FC, I'll select that. Final question here :scratch2: there were a few caps that I couldn't find FM or FC or HE series models- should I go back to my list and look for higher voltage models that will be in the FM FC or HE range? I had a nichicon VZ and two panasonic M series parts in there.That is just the rating, the 4.7uF is the capacitance or the amount of energy that is stored. You can go up in voltage no worries, just the size will increase somewhat.
