Thinning "Vintage AR" sealant?
mike j
Too many hobbies
I've got some of Larry's goop that is getting quite thick.
Anybody know what I could use to thin it out?
Thanks!! Mike
Ah yes. I knew there was a gentleman on AK that was involved with the product, but couldn't remember his name.
Thanks, GD70!!
Sure thing. He's great guy and knows his stuff. He was instrumental in helping me restore the drivers and cap swap in my AR LST2's.
Thanks!! Mike
Mike,
Toluene (toluol) is the solvent to use. Lacquer thinner is not a good idea, as it will make it congeal and become cloudy. The sealant will thicken somewhat at cold temperatures, and is easier to apply at warm temperatures.
GD70,
Thanks! You are doing a great job on those LST 2's!
Roy
Thank you very much, Roy!
I've got a third of a bottle left and two pair of KLH 20's to treat still.
Mike,
GD70,
Roy
Thanks Roy!
Where does one buy Toluene, just in case I need to thin some of mine?
I knew someone would ask that question...
It is getting very hard to find. Ace Hardware is where I purchased a large quantity last year, but I have not seen any on the shelves lately. It was used in the painting business, and may still be available through paint stores. I have never seen it in Lowes or Home Depot. There is a toluene substitute out there, but I have not tried it.
Roy
Would xylene be an acceptable sub for toluene? Chemical structure is similar as is solvency. I haven't seen straight toluene in years but xylene is still readily avail from places like Home Depot and Lowes in my locale.
Well, I picked up some xylene and thinned out the sealant and it looks like new, not cloudy at all.
Me thinks it'll work great.
FWIW, I saw toluene at a "Jerry's Artarama" store, which carries supplies for oil painters. So you might find it at an artist's supply store near you.
my locale.
To expand on Steve's comment about similarity, for this purpose probably, but not exactly identical.
Toluene is methyl benzene, a benzene ring (six carbon atoms in a ring with hydrogens stuck on them) with a methyl (CH3) group stuck on one position instead of a hydrogen.
Xylene is di-methyl benzene, a benzene ring with two methyl groups. (Different names exist for it depending on the position of the methyl groups around the ring of six carbon atoms.)
Tolune is more volatile.
As always, do yourself a favor and don't use them in unventilated areas as breathing low-molecular weight hydrocarbon vapors is not a good idea as it is carcinogenic and hepatotoxic.
I used a little Xylene to thin the goo once for a pair of KLH Model Thirty Twos. No cloudiness, good evaporation after application, no obvious change in the remaining stickiness, either. Menards has Toluene, but only in gallons. It would take me 5 lifetimes to go though that. Even the quart of Xylene has been in my garage for 5 years.
This old thread reminds me, it's almost time to get more stuff from RoyC!
