Aluminum Blanks
carpinus7
E&B Salvage in Adrian, MI has 12"x12"x1/8" aluminum blanks for $4.00. Kinda thick but the price is right. They are not polished but are square and in good condtion.
Stock up, that is an extraordinarily handy size for audio projects.
With wood edging, you've got a preamp, monoblocks, etc.
Perfect for tube gear.
I too was interested, couldn't find it online, and was waffling about trying to call them.
Now at least i can speak up about my interest.
Anyone want some of these?
Back when this thread started, carpinus7 was cool enough to ship some of these to me. They're perfect for DIY tube amp projects!
I found a local metal supply company that will sell me more of them, but the cost will be slightly higher.
If I buy 8 plates, the cost would be around $11.00 each. I was thinking I'd keep three or four of them. Would anyone want some of these?
They'd be 1 foot square and 1/8th inch thick. I was able to work the material pretty nicely with a stepped bit on a drill press.
Here's a couple pictures from my project:
attachment.php
That is one good looking amp. Is that one of your first forays into electronics DIY or are you somewhat between master and national treasure? :D
Thanks guys. westend, this amp is my first and only DIY so far, though I've got another in the pipeline. Check the links in my signature if you want more information on it.
Anyone interested in the aluminum plates I mentioned?
Yes, on the plates. Will PM you.
Redboy - nice use of the aluminum:thmbsp: ! I've gone back a few times but they haven't restocked those size blanks.
They do have some stainless steel pieces but I think they would be harder to work.
carpinus7, after working with this material, I'm sure I wouldn't want to mess around with stainless! I'm not sure what the proper tools for that job would be, but I know I don't have them! Thanks again for picking up those pieces for me in the first place!
I've worked with both materials (building robots, not A/V gear, but similar requirements) and aluminum is MUCH, MUCH easier to work with than stainless steel. No comparison! The only thing that is easier to do with steel is weld it (welding aluminum is NOT an easy DIY thing); bending aluminum is a bit tricky, too, but not hard to learn; drilling, cutting and milling it is MUCH easier than steel, as it is much softer.
At $4, those sheets are a "steel" (sorry, couldn't resist...). Barring an economic collapse (triggered by USA subprime-credit issues, perhaps?), all metal prices will continue to go up in the next several years, at least, as demand continues to feed the growing economies of China and India. Wouldn't be a bad idea to stock in any cheap metal stocks you can afford and will need, while you can still find them.
A thin stainless plate wouldn't be that bad to work with, just more time consuming.. a very fine tooth jig saw or band saw doesn't do too bad cutting them, but plasma works a lot better, of course.. A thin plate wouldn't be too bad to drill either, you just need to be sure you've got a very good quality set of bits.. It is a lot easier to bend than aluminum too... not prone to cracking like aluminum...
I think the looks of a polished stainless plate or even a nice brushed plate might make the extra work pay off...
You'd be surprised how easy a water jet cuts through stainless steel (or aluminum) and the results are perfect. A lot of shops can scan in or program your component layout and Bingo, it's done.
Metalwork is definitely the worst part of DIYing. When I made my first stuff back in the mid-90s it was nothing but bud boxes and hand drills. I ended up with dents (from pressing the drill down too hard), scratches, and misaligned holes from the bit skipping.
These days I farm that work out - preferring the front panel express software - though prices are a little high. I also have a friend who does carpentry, so he makes the wood cases. For example, for my C3m preamp - the top plate from FPE cost $90
