That has nothing to do with ruggedness. Tubes with large plates are more prone to microphonics due to the size of the plates. There are a few instrument amps I'll use an LPS in, but for most (especially combo amps) long/large plate tubes are a no-no.
That is way beyond the spec for a 12AX7, the spec is 100 volts. RCAs can go up in smoke at 200 volts h-k.
Okay, fine. I was referring to use in audio amps. and while guitar stuff may use higher voltages, they do tend to run lower currents.
Whatever. You aren't the only person who has some first hand knowledge of what goes on in a guitar amp. And your opinion of JJ stuff is not widely held, but I'm glad you like them.
Your opinions regarding the LPS are not valid in audio gear though. It's a fine tube for audio use.
I agree with you wholeheartedly on the first comment. I can't put an Ei in the first stage of anything but a lower-gain type amp, like a Fender-style circuit, without it ringing, and combos are kinda out-of-bounds. However, for some reason, the ECC803S seems to be able to take the vibration very well. I can't explain it, even JJ says not to do this.
As to the lower currents, you're may be right there, although most guitar amps actually use lower current than one would think on the preamp tubes; they tend to get biased colder rather than warmer to create the asymmetrical distortion artifacts.
I realize JJ is not a highly appreciated name in new tubes. In fact, I had a KT77 go out on me most spectacularly in my Dynaco. However, in the hundreds of JJ tubes I've used, I've only had 1 preamp tube failure. Their power tubes (especially nowadays) may be another matter, but I've had great luck with E34L's, EL34's, and their 6V6S's.
The spec may be 100V, but guitar amps regularly run the cathode voltage at 130-170V, and Soldano pushes the 200V level in places.
The LPS is indeed fine for audio gear. I just would keep it away from a CF circuit that ran the cathode at more than 100V. Oh, and as far as great sound goes, the LPS, to my ear, can sound as good as just about anything. I just can't use them as tube #2 in a Marshall, or most of the tubes in high-gain amps (which tend to use several CF circuits on the distortion stages).
Thanks for your input, though. When it comes to hifi amps, I can tinker with them, but I don't have the intimate knowledge that you (and MANY others) here have. Wish I did, but I need to get a few more years of hifi under my belt. Don't know if it'll happen, as I'm backed up for a couple of years on guitar amp builds.
Once again, thanks for the input. If it weren't for you guys, I doubt I'd be listening to my ST70 and PAS setup, nor my Thorens TT. You guys made all the refurbing possible!
rooster.
