12AX7/ECC83 Recommendations?
artsybob
Does anyone have a recommendation for a good 12AX7 (either new production or NOS) for a tube amp phono stage that isn't ludicrously priced? Would like to hear what the AudioKarma community thinks
^ I haven't tried them, but when I asked Jim McShane that is what he recommended as well. I ended up not buying any because the old Telefunkens in my receiver are still working; the issue that led me to reach out to him turned out to be a dirty socket, not a bad tube. I may end up getting some anyway just to try.
They beat me to it.
I bought an Ear834 clone phono preamp recently. Jim McShane recommended to me a couple choices. I chose matched pair Sovtek 12AX7LPS for thier low noise and one Genalex Gold Lion for warmth in buffer position. Don't recall the other tube he mentioned as alternate to use for buffer.
Actual cost I don't have at hand.
No connection to Jim McShanes business.
Don't diss tested used tubes; I use them all the time and they have a much better track record than new production tubes of which 2 of the 6 I bought failed, as opposed to dozens, maybe hundreds, of vintage tubes that have worked well.
Black plate RCAs are well regarded, but given the plethora of uses and users you'll undoubtedly find myriads of positive opinions on many brands and configurations (getter, plate, etc). If you have a local tube buddy see if you can borrow a couple to audition.
I saw TubeDepot sells used US-made NOS for $24.95 apiece. I'm working if it's worth the plunge to get two and pay extra for matching and testing for microphonics? Hmm...:idea:
IMO, you do want matching, so both channels sound similar. Microphonic tested well, might mean you get better tubes out of lot seller has. Testing can't turn a bad product into good though.
I'm no tube expert.
Brent Jessee's site, Audiotubes.com has a LOT of tube info. Reading there can be tube educational. He sells tested NOS tubes.
I have no connection.
Sonotone 12AX7/7025 cleartop side getter is an excellent choice. These are very low noise and sound clear and full.
They can be had for cheap. I bought 4 for 60 that were Fisher labeled.
These were manufactured by Sonotone in the 50’s, and have a smaller glass envelope than any other 12AX7 I’ve seen. Long plates.
I've also heard good things about the JJ's and will give them a try at some point soon--thanks for reminding me, guys!
