So they draw different current than other 12AX7? Higher or lower?That’s terrible. I have to re-check in my Fisher 400. They are on the same string I believe with Matsushita tubes in the preamp.I bought a few of the LPS variety from Jim and wanted to use them in the phono stage of a Scott receiver, with some other brand in the tone and line stages. Bad idea, as the filaments were quite different from the other tubes and the voltages across each tube (in the DC serial string supply) were way out of spec.
I like RCA 7025 or 12AX7A tubes.
I'd second the 7025 old manufacture tubes. A low noise version of the 12AX7 supposedly designed for applications like phono stages. It's what I've settled on after trying Telefunkens, Mullard 10Ms, 5751s, etc, etc...
Got to agree on JJ's. I have had excellent results with their ECC83S/12AX7-S. This tube resembles the 6DJ8's construction (frame grid style?). They last a long time and my experience is that they don't become microphonic like many other newly manufactured 12AX7A's. And, they are relatively cheap at around $12.95 from many suppliers (Like AES in AZ). I haven't tried the JJ E88CC which looks similar at double the price.I strongly agree. When tubing my phono stage these were the tubes that did it for me. IMO they easily keep up with vintage products and fly under the radar.
JJ ECC83S has a conventional grid in a "box plate". E83CC has a frame grid in a similar plate.Got to agree on JJ's. I have had excellent results with their ECC83S/12AX7-S. This tube resembles the 6DJ8's construction (frame grid style?). They last a long time and my experience is that they don't become microphonic like many other newly manufactured 12AX7A's. And, they are relatively cheap at around $12.95 from many suppliers (Like AES in AZ). I haven't tried the JJ E88CC which looks similar at double the price.
Sovtek 12AX7LPS. Low noise, spiral-wound filament. Matched for phono.
New term = ANOS. "Almost..."![]()
Wait! These were GE 7025? Not 5751?Reopening a Zombie Thread for a bit of newer info than 2022:
I recently bought a Pro-Ject Tube Box DS2 phono preamp that came with mystery ECC83/12AX7 tubes, I could not tell what they were as they were covered by some EAT aluminum finned "coolers" that actually don't do much cooling (if any) they do more to help dampen the tube to prevent microphonics. Convention wisdom is that Pro-Ject used either modern Tong-Sol or JJ tubes, but when I finally got the cooler off one of the tubes it turned out to be a Psvane ECC83. It was not bad at all, but the sound stage was a bit 2 dimensional, confined to behind the front of the speakers. Several reviews of this tube said it was a bit microphonic, maybe that is the reason for the cooler/dampers ???
I rolled in a set of GE-JAN 7025's to see what difference there was but they got very bright/brittle after 3-4 hours, so back in with the Psvane (the 7025 will be spares for my guitar amp). I did a lot of internet sleuthing and determined that a set of JJ E83CC frame grid tubes might be worth a try.
Yowza! These JJ E83CC tubes have strong tight bass (SLAM?) excellent mid range where the voices are crystal clear, and sweet but not rolled off highs. Best part is that the sound stage is now wide, deep, and high and 3D- It now sounds like performers are in the center of my room.
View attachment 3270271View attachment 3270272View attachment 3270274View attachment 3270275View attachment 3270276View attachment 3270277
my bad, they were the 5751- I fixed the first post (soo many numbers for pretty much the same tube )Wait! These were GE 7025? Not 5751?
