12b4, 6ca4 build questions....
Oh and i had the clip from the positive clamped on to the top of the 2540, on the metal part where the screw goes thru... is that ok or no...
Its about 1.310 not bad it bumped it up! Hey is the 3545 supposed to heat up like that?
how hot does it get?? I wouldn't think it should get warm at all. Better triplecheck the wiring.
yea, that is electrically connected to the drain. OK for now, but should be connected normally to the pin in the final unit.
It gets hot, too hot to touch, could be backward, think that, also the reason i was testing up on top of the 2540 is the pin i have nothing connected to isnt working, maybe i need to flip that around??
I know. hehe :D im not gonna apply any voltage to it till i show you some pics...
But i do want to thank you, for helping, the last 40 posts were a learning experiance, but hey it works now till i show ya the pics! im gonna go out and try to find someone who can cut the Aluminum plate for me tommorow, get a digi camera to show ya picks, and work on mounting the power supply.. but thanks agian brick! :thmbsp: Im happy i got one channel done!
Well i see if you can answer this real quik, you know how they both have flat sides... should both flat sides be facing the same way.... can you answer that without a camera? Im wipping up a diagram to show ya... if it works! give me a sec...
No problem. It'll all pay off when you finally get some tunes through it:music:
Now....to wet my own sponge....:D
:thmbsp:
Hope you can read it and understand it... ask questions if need be!
have to pardon the typos, was hurrying...the 2540 is also flat side facing you..
If the DN2540 is oriented so as you can read the typing on it (which i think is how you picture it), then the following corrections are in order. This may fix your hot DN3545.
(edit: posted the right pic this time)
I can view that one just not the real pic... i see what i have wrong now.. brick thanks man +1 :thmbsp:
I need to flip the 2540 around i have it backwards... im gonna heat the iron up! wooooot! To bad i dont have another trim pot id do the other side, im gonna build the other side and try to get that other trimpot working and have both done woooohooooooo
yes, that stuff you mentioned is the same bar of solder.
I'm leaving for the weekend to somewhere with no internet:sigh:. Jay or Douglas, please take the torch:thmbsp: I'll be back Sunday evening.
good luck
Ok well have fun, :thmbsp: I just got both channels done, and are working great! :D Looks good, will get some pics up sometime..... Jay or doug anyone? hello.... hello..... helloo (thats supposed to be an echo) :smoke:
:banana: :banana: :banana: :banana:
Well heres an update, i got the preamp top plate almost done. i got the tranny mounted, sockets, rca's, light, ummmm.... pics to come! wooooohooooo... if anybody's out there... :D
orange, orange, orange you glad I stopped saying orange
I'm here Pal :yes: I'm sort of intermittent though, as I'm trying to fix some leaks in my basement floor. They've been a PITA for a few years now, and I'm sick of it.:thumbsdn: I even had a beautiful pair of large advents ruined after a heavy rain once.:thumbsdn: Wish me luck and post a pic of the chassis.:thmbsp:
Im just trying to find some wood still ,so i can make a base, hey if i can make the kc vacation, ill bring it, to show you an accomplishment of mine! first build! awesome....
I got my crappy cam but it will give you an idea, its nice just the cam sucks! The smudges arent deep, its just fingerprints, they wipe off with a terrycloth.. but hey its first build!
I was wondering what wire i should use for what, i got the solid copper stuff that jay supplied, and a foot of black thin twisted stuff which im thinking should go for light.... and whole bunch of purple. should i do the 12b4's with the copper wire and heat shrink over it? Basically i think what im asking is what guage should i use and where?
I'm back! Glad to see you got your CCSs working.
Use the solid copper w/heatshrink for short runs (like less than 1.5 inches i.e. if you need to connect two pins on a tube socket together, like pins 4 & 5 on the 12B4s), and the "super purple power wire":D for longer stuff, like heaters. When running heaters, wrap a tightly-knit twisted-pair out of the purple stuff. You don't really have enough heater current to worry about overloading that wire.
