hmmm, that probably blew up because of a short elsewhere, which might be a good thing since resistors are cheaper than tubes and mosfets. How long did it take after power was applied until the resistor smoked? Are both the CCSs hooked up correctly? If one was backwards, it could easily look like close to a short-circuit. Post a picture if you can so we can get some more sets of eyes on it.
It was only about 30 seconds, then i started smelling something warm ,flipped it over and seen where it was coming from.. unplugged it. I powered it up at first w/ no tubes in it, that went goo, i shut her down put the tubes in it and 30 sec later smoke!
They won't light up unless the 12B4s are warmed up and drawing current. If drawing too much current, they may open up, acting as sort of a fuse. You can test them with your meter on the diode setting, they should read about a 1.7 volt forward drop if they are ok.
