merlynski
Curmudgeon Electronicist
I am wanting to replace the drivers in my subwoofer setup. They are rattling badly, like disintegrating cones. The cabinet is a beautiful old church organ bass unit that has two 15" forward facing drivers, two 12" drivers, one forward, one upward (out the top) with an open back, basically open baffle I guess. Also my system sits on the cement floor of my basement, with open space behind the cabinet. I have only been using the 15" drivers, driven by one channel each from a Cerwin Vega Pro CV-900 amp, fed by the sub output from my HT amp, mono into both channels in parallel. After 12 years I was expecting this to happen cause I like bass, loud and room filling. The amp will drive 2Ω-8Ω speakers and is bridgeable. My max spending limit is around $250 for this project. Do I replace both with good long excursion drivers, or get one higher end driver and bridge it? Or . . .?
FWIW I play Skyrim on a Playstation3, (using the optical connection) which has some pretty good bass effects and vocals, and movies from DVD and Bluray. I like the earthshaking bass.
EDIT: corrections
EDIT: corrections
may need to run 12” subs .s on a different power source.
