1962 Eico ST-70
b brian
Well-Known Member
Would you buy this for $120
1962 GARAGE-FRESH RESTO PROJECT/ EICO ST-70 Integrated Amp, all original EICO tubes, does not power up
one of those transformers might have an issue... but the OPTs should be OK and they're quite good; easily worth the asking price.
...oh, and not to mention the EICO 5AR4, which is almost certainly Mullard OEM.
A bit off topic but does it really matter who made the rectifier? Signal and outputs yes but a rectifier isn't in the signal path, right?
The issue isn't (as far as I am concerned*) - it's robustness. The Mullards will last for years and years - most modern 5AR5s; not so much.
The 5AR4 was the most "high tech" vacuum tube HV rectifier developed, and it was developed principally for hifi use. It is very efficient (low voltage loss) and can deliver quite a bit of HV for its little package. There've been some poor performing variants - the classic Mullards, though, generally might be expected to last a lifetime (or more).
* Although it can be argued that everything in the sonics of an amplifier will ultimately trace back to the power supply.
Thanks for the explanation. Makes sense to me.
