C11 thru C14 are part of the BIAS CIRCUIT, NOT COUPLING CAPS! Use Nichicon 100uf 35 or 50v TVX series caps for these. There are NO OUTPUT COUPLING CAPS. If the pots are still there and connected DO NOT TOUCH. There is a very specific procedure and you will need to adjust them both at the same time. Hard enough for most tech's to do correctly, almost deadly to the amp if a non tech does it.
647-TVX1H101MAD1LS is 100uf 50v
647-TVX1V101MAD is 100uf 35v
100uf 25V Orange drops would be about as big as a grapefruit. Any electrolytics in the chassis bump the voltage up 1 level minimum to handle the increased wall voltage and attendant increase in B+ voltages.
