Some disassembly may is required. If each one grey wires has two conductors, then it may be a simple matter as removing the XLR and soldering in the RCA's. You just need to know which is left and right channel.
If this is not the case, you may have to go back to the PCB that's mounted under the tonearm base and solder in new wires. Lots of online info and possibly youtube videos showing how to do this.
jeff
