But the first drawing isn't how he's wiring his amp. For his 220 volt connection, there is no neutral connection!!! The two coils in the primary are connected in series rather than parallel, that's all. The primary is connected to L1 and L2. Again, neutral is not used as a current-carrying conductor, so vector cancellation isn't even involved.
Absolutely correct. His situation is load 3. I suggested the first drawing's configuration as a more useful and cost-efffective solution. No off-standard 240V receptacles/cord caps required (assuming he actually changed them). The wifey could plug in her vacuum, whatever without smoke. The difference in cost is 2 vs. 3 conductor wire vs. 240V cord cap/receptacle and the inability to use said receptacle(s) for anything else. His gain was mainly due to larger gauge wire. So long as he's happy with his choice my opinion is moot.
