2238 Filter Capacitors
potch
Hello, Looking for specs along with width and height measurements for the filter capacitors on a 2238 receiver.
Note that this is NOT the B version.
I use Nichicon LGY1J103MELC50 which are the same diameter as the stock filter capacitors (35mm) and height (50mm). They are 10000uF @ 63 volts. In stock at DigiKey and Mouser. Many other 35mm capacitors will work, I just like these :)
I like the LGY series parts too!
