2252B Chassis Cover
there is a WC-22 variation case for these models with the the heat sinks on one side and you do not need the metal cover with these. they have one big cut out on the bottom vs 3 cutouts on the standard
i have talked with a couple of original owners of 2285B models that had the WC-22 case and they said it was sold installed with the 2285B not as an option and that there was no metal cover. so i you were able to buy them either way. if no wood case they came with a metal cover. mine came with a wood case no cover. mine is the euro version but i havent been able to verify if that is the only one sold with the WC-22 installed.
Which is the proper way to create the "chimney effect" to draw air from the bottom up and out the top passing through the heat sink fins along the way. The side vents reduce the air flow by bypassing half of the heat sink, and choke off the front portion of the heat sink altogether. This variation is the proper one for the 2252B, or any other single side model it fits. :thumbsup:
What side vents are you meaning? there are no side vents on the B metal covers only the non B and there is no bottom on the WC-122 to prevent air flow up.
I happen to own a 2252B in the cabinet you desire to own.
Bought from the orignal owner and was informed the cabinet was on it when purchased.
I would think the way yours in now would be fine for cooling the unit.
If asked to, I will not get it out for another picture anytime soon.
So Marantz put the wrong case on the components for the catalog and in the owner's manuals?
Not necessarily "wrong", but a cheaper alternative than the WC-22, and match the "new look" of the B series. They were an "add-on" option that simply puts a "hat" on the whole thing. That's why they are a bonnet style instead of the slide-in style. Using the metal case, they saved money on grille material, and labor to build them.
Which makes sense with a WC-122 case.
But the 2252B metal cover does not have side vents. So you would need it for the WC-122 to maintain the proper air flow over the main heat sink. If you like the 122 better, then get the metal cover without side vents and you'll be good to go. With the WC-22 , you won't need the metal cover, and shouldn't actually use it. "Normal" listening levels probably aren't any problem. Cranking it up is where the heat/ventilation becomes an issue.
Yes, correct. My 2252B metal cover has no side vents. Your photo of the "variation" of the WC-22 is for the B models with a single heat sink on the right side.
The side screw cut outs have a plastic offset insert for allowing of different models.
For models with two heat sinks. Single heat sink models of the bonnet style should not have open side vents. It was a "one size fits all" approach by the bean counters and sales people without regards to proper air flow requirements of differing models.
Why wouldn't you have the chimney effect with a WC-122 case from air coming in the bottom of the unit and exiting the top? I think Chris mentioned that on the first page.
The WC-122 having side vents disrupts the flow. It lets air in the side higher up the sink and reduces the flow coming in from the bottom. It's like having a hole in your chimney, and wondering why the fire won't burn right. The draft isn't as strong where it is needed. But if you have a metal cover with no side vents, that becomes moot and there will be no "hole in the chimney".
