No, the old ones had two solder lugs each. I use snap-in types and cut the unused terminals off. I add ring terminals for wire connection, a neat trick I learned from Echowars.
Tom
Thanks Tom,
Do you have a photo of that?
Tom
I posted this back earlier in the thread, it's kind of hard to see, the white wires go to the negative and the red leads go to the positive leads of the cap pair and attach to the cap with ring terminals.Thanks Tom,
Hi MarkyM,
I noticed you used 1 Panasonic FC on PS board.
Any particular reason?
As I got 2275 recently, I am watching your every steps for recap.
Do you mind sharing your caps list per eeach board?
Thanks very much.
I must be missing something. Why did you replace so many capacitors? Was the unit just not working? Why fix it if it's not broken?
... I've never tackled a receiver as it looks like a daunting chore.
I like you SG-80, use the heck out of mine.
Tom
Indeed, it makes this job a lot easier.
Boy, the service manual procedure for FM alignment is kinda strange. In Step 5 it says: "Decrease the signal generator output until the audio output level decreases with the decreasing generator output". Huh??? This is not AM
Must be a poor translation from Japanese. I assume what they mean is decrease the signal generator output to where the audio starts to get noisy (and reads low on the signal strength meter) and tune the adjustments for maximum signal (sensitivity), then increase the signal generator output and fine-adjust for minimum distortion.
