klamsoss
Be willing to fail and try again.
Oh boy am I glad there's some folks active on one of these. @catrafter @Steven Tate @pga7602 @MBuras I'm looking at you guys...
I am like 99% done with the rebuild on my buddy's receiver and it has worked wonderfully so far. I worked my way through each board and tested periodically to make sure everything was still working. No issues. The last thing I did was the power amp modules and replacing the lamps with LEDs. All good... right up until the other day when I went to do all the final voltage adjustments.
For some reason it blew the fuse on the power supply board. I could detect no other issues and it wasn't drawing excess current (started it up initially on the DBT, but typically the relay wouldn't click for me until I used the AC amp-metered outlets on my home built DBT/Voltage/Current unit). Both prior to, and after the fuse blew, it was drawing around 0.75 amps according to my meter, and that is commensurate with other low-volume testing I did while going through the rebuild.
Anyway, I ordered some new fuses of the appropriate amperage rating (although I couldn't get the same voltage rating, so I went with something higher... fuses are for current, not voltage, right? original was a 0.2A 250V and new is 0.2A 600V... only one I could find on digikey that was the right size with the current rating I needed). The old fuse looked like it was mechanically broken... not smoked, burnt or melted like other fuse filaments I have seen when they blow.
So, last night I popped in the new fuse, turned the thing on, and everything seemed fine. The FM sounded normal and the volume worked normally so I started hooking up my DMM grabber probes to adjust the power supply voltage when I saw smoke start coming out of the left side power amplifier. The current meter wasn't showing anything weird but I shut it off anyway. I unplugged, discharged all the caps, pulled that amp module and inspected it but I couldn't find anything wrong with it.
Okay, reassemble, try again, I'm thinking maybe it was just some flux? cat hair? my hair? or something else silly that was providing some sort of low-level short... (even though I'm good about cleaning that stuff off, and the smoke didn't really smell like solder/flux/hair).
NOPE! About 25ish seconds after I powered back on, I got a POP and a spark coming from the vicinity of the inductor on the driver board (couldn't tell exactly) and also a pop from the little test speakers I use. Shut off immediately (though I did double check the current and I had the power supply voltage metered as well... current was still normal, around 0.75 amps A/C and the power supply voltage was maybe 36VDC, so slightly high, but not crazy). Not wanting to destroy anything, it's been shut off and unplugged for the last 18 hours. I took a look back just now and I don't see anything obvious. no popped capacitors, no blown resistors, no signs of anything really burnt either. The only hint of ANYTHING is the pins on the power jack for the driver board do look tarnished in a way that makes me think it was heat. Also, the plastic connector that fits on those pins smells like the smoke I got the first time.
Any ideas?
Any ideas?
