Thanks Avionic. I looked up the spec sheets for each and I thought i had found something at Mouser that appears to be an adequate replacement but when i tried to do it again, nothing came up.. Would you be so kind as to take a look and if you are able to, make a suggestion on what you think would work. I can figure out how to mount say a TO-3P form factor to fit if necessary. I have not found any reputable source for the MT200 originals anywhere as of yet. As you said, BD is out of the 2SC.
Type Designator: 2SA1494
Material of Transistor: Si
Polarity: PNP
Maximum Collector Power Dissipation (Pc): 200 W
Maximum Collector-Base Voltage |Vcb|: 200 V
Maximum Collector-Emitter Voltage |Vce|: 200 V
Maximum Emitter-Base Voltage |Veb|: 6 V
Maximum Collector Current |Ic max|: 17 A
Max. Operating Junction Temperature (Tj): 150 °C
Transition Frequency (ft): 20 MHz
Collector Capacitance (Cc): 500 pF
Forward Current Transfer Ratio (hFE), MIN: 50
Noise Figure, dB: -
Package: MT200
Type Designator: 2SC3858
Polarity: NPN
Forward Current Transfer Ratio (hFE), MIN: 10
Noise Figure, dB: -
Package: MT200
Possible replacement for 2SA1494 -
https://www.mouser.com/ProductDetail/?qs=HVbQlW5zcXUavFy4M6DFSg==
Possible replacement for 2SC
