2SC1116 Transistor dilemma.
To clarify, real one weighs 20.160g, 1st fake is 20.170g, 2nd is 20.090g.
It's really hard to say without better test equipment or actually blowing one up. Or cut the top off. Then I'll have 1 that works if it turns out to be real. Need one of those x-ray machines they use to see internal fractures in metal.
If you don't damage the cap (or the die/leads) removing it, you can just epoxy it back on. But genuine Sankens will be a little "tough" getting off. The fakes usually pop right off with ease.
Now if you can rig up a tester where you can put a load on it, then you can monitor the heat at certain current levels. If it gets hot before it should, you know it is fake. There are some videos on You Tube where people have rigged up testers for this purpose. Someone with a "real" curve tracer can perform the same tests and more.
Do you have a pdf of the design?
I am not a good electronics designer, so keep in mind that you have a chemist trying to do electronics here, so be aware that high voltage is no joke. That said, by all means i am attaching the diagram and the printed circuit that i routed.
I built the circuit on cheap printed circuits, and then what did not work i modified by cutting tracks and soldering wires. The SOA_Tester has one circuit for testing NPN and another for testing PNP transistors. It drives the base of the transistor under test and you can adjust the base current. I used separate potentiometers for NPN and for PNP transistors.
The SOA_Test_Control is meant to hold relays and it is used to switch from the NPN to the PNP test. It uses relays to switch the polarity of the collector voltage, and it commutes between the leads that connect to NPN or PNP DUT.
The HV power supply that i used was a 220V to 110V transformer, rectified with a bridge and a 5600uF capacitor which then fed an adjustable current limit. I can not locate the schematic for that, but you can use an external power supply with this. My HV supply could only deliver some 30mA maximum, but I did test power transistors by disconnecting that power supply and connecting a 30V 2A power supply.
I hope you find it useful.
Well gents, an update. So I decided to go ahead and cut the top off 1, just to be sure and take a look at the results. It appears these are either insanely good copies or are in fact the real thing.20200913_182305.jpg
Welcome Joey !
I am one of customers and be always happy with what I have bought from you
best regards
PATRICE
Clinique Audio
FRANCE
HI There, My name is Joey and I'm the new owner of wehavethatitem, after reading your posts on here I'm feeling terrible that you are having bad experience with the new management , Fyi just to clarify that all the parts we sell on a daily basis is the same stock from the original owners Adelle and Orrin, after Orrin passed last end of the year Adele reached out to us if we can take there baby and take care of it for them from now on cause she has no strength doing it by herself, so just to clarify if you have purchased from us before you will be getting the same quality as previously, and the same service you are used to getting, yes ill say that from over 1 millions parts some of them are bad but we would never sell any counterfeit to take away the good we have out there until now with over 12 thousand positive feedbacks on our eBay store, feel free to reach out to me my email is yeswehavethatitem@gmail.com with any questions you may concern thank you i look forward hearing from you or anyone Stay Safe and have a happy holiday season
  • Haha
Reactions: trs
I have always had a good experience with "Wehavethatitem", whether with Orrin running it, Adelle running it, or now Joey running it. I know they always looked to buy and sell only Reputable/Genuine parts.
We are lucky to have places such as this, where we can buy many hard to find parts local, without having to take a chance on buying from the other side of the world, and waiting a month to get them, and keeping your fingers crossed that it will work.
