And the good thing is, that amp uses plenty of negative feedback, and produces enough power that even if you have 50 clean watts at 35Hz, 50 Watts is still a lot of power for an amp you basically got for free. The coupling cap values don't look like they were chosen to limit bandwidth. All in all it looks like a very solid design, a variation of the classic Mullard 5-20, but with fixed bias, a different sort of input stage, and a lower impedance driver tube. The only thing which could make this amp sound bad, is if the transformers are no good. or if the 6GT5 is a bad sounding tube (I have no experience with it, but also no reasons to think it's bad) I think this design really has a lot of promise.
Another thing going for them, is a regulated screen supply.. in my experience, a regulated screen really helps a pentode based amp sound good, because the screen voltage determines gain. Even if the plate voltage varies, under load, it won't matter that much if the screen is regulated. And what a clever way to do it, by using the old ham radio inspired power supply design to get 1/2 the plate voltage for the screens, and then use tubes with a low screen voltage so only one regulator is required. This is obviously a late tube design, because it employs a very mature application of the design principals which were well known since the 50s.
