4K AV receiver -how to connect s-vide
Peter cli
My laser disc outputs s-video . What is best way to connect to a 4k AV receiver ?
Do i need got get a SVideo to HDMI Converter ?
Thanks, Peter
If you specify the make and model of the receiver and laser disc player, you will get a more useful response to your inquiry.
If the player has composite video (yellow connection) use it if your TV has the same input. Even if you buy an AVR with s-video input, Like my Onkyo 575x, Most will not convert them to component or hdmi outputs.
It looks like you can buy a dedicated s-video to hdmi converter, but the ones I saw are expensive. Even then, the conversion itself might degrade the signal more then the composite video output.
If you have a large collection of laser discs and wish to keep them, I would buy at least one extra working LD player. Or do what I did with my small collection of video tapes and replace the ones I valued with the DVD for $5 - $15.
The very rare LD's you can't find on dvd can be converted to dvd or blu- ray for about $25 - $30.
Use the composite video output to connect to the composite video input on your new receiver. This is what I do. Just make sure that when you purchase a new receiver it has a composite video input. Many do but many do not.
It should also be noted that not all AVR'S even convert composite video to hdmi. My new (2018) Yamaha A770 does I believe, But my older Onkyo doesn't. That was frustrating.
Composite to hdmi converters are cheap, so even if the tv or avr has no composite input, Its not a problem.
isn't composite video a worse option than s-video?
You are correct when you connect an s-video player to a tv with an S-video input. These TV's have been calibrated specifically for this purpose. When I compared the two, I found the colors in s-video to be much richer.
But when we convert an s-video source for proper playback through an hdmi input it may loose much of the advantage as these two formats aren't very compatable.
We probably can convert s-video to hdmi quite well with a professional grade processor, But I doubt the ones we buy on e- bay for $200 - $300 would cut it.
S-video is a step above composite video.
Problem is AVR/processors started dropping s-video ports maybe 10-12 years ago. Some may still have composite video ports and component ports, and typically can convert those inputs to HDMI output.
So, I think your choices in order of preference are -
Convert S-Video to...
1. HDMI
2. Component
In the case of using composite the receiver/processor probably still has those ports and should convert the signal to HDMI by its internal conversion.
