touchdownT
5000X with original f-1040-1 boards here. Have a set of bonzoro boards rev d f-6013. Coming into a couple issues with the new boards.
Where do I connect power leads to the reproduction f-6013 from 1042-1 diodes stack.
Originally DC+ went to the output cap and DC went directly the the 1040 board and was jumped to the other 1040 board.
I have original schematic and service manual with the 5000x with the 1041.Have read over bonzoro instructions and the service update.
Also, want to verify the service update says to cut two wires. Can the wire from the power caps be removed from this as well then?
Hopefully someone has had this same problem and can give me some insight.
Thanks!
- Cut the gray and blue leads which connecting 18kS
(RO33, R034) on the terminal with the F-1040.
Thanks!
