jstang
Honey,I can't hear you...
Restoration includes far more than caps....you can replace with exact factory fresh original type caps and still NOT come up to the original sound.
So many electronic components beside caps degrade over time.
To assume a 46 year old unit without full and careful restoration can represent the factory is extremely misleading. You are only fooling yourself....
Would you expect an unrestored high mileage 1966 Corvette to perform like new? No....!
I would not even drive an unstored high mileage 66 Corvette on the street....
Would you power up an old unit without a variiac or dim bulb...? No...!
But yet people are afraid to do a proper refurb of a 7t.... :scratch2:
Every old Marantz I have owned, has be powered up slowly and monitored for current draw... Then tested and restored..... AND HOT RODDED....if appropriate for that unit.
The 7t is a great unit to hod rod....
Would you take two unrestored high mile muscle cars from the sixties, that have been sitting for years and try to recreate the Quarter mile times as recorded in tests from back then in the sixties? No...!
Some audio units hold up great over time and others do not... Just like cars...
Some audio units respond well to hot rodding and other do not...just like cars...
Yes at minimum my gear gets 100% tested refurbbed... And some are hot rodded...and some are restored to 100% stock....
But no way would I compare two 40 year old un-refurbbed units, that is a waste of time... If you are into archeology, then why even turn your units on?
JohnK
JohnK
IMO, that is a valid opinion. It is a real assessment of an unrestored piece of vintage gear.
JK, you obviously also don't like the sound of unrestored gear. You're absolutely right about stuff not aging well. But if you "restored" the 7T with new but exactly the same type of caps, resistors, tantalum caps, etc. as was original, there's a chance the 7T could sound better than stock but still sound poorly against what we have today or know today about components.
Your restoration has come from pretty careful new and different passive component selection and listening tests plus knowledge of later circuit techniques that weren't used or available when the 7T was designed and built. If its a "super 7T", so be it. But not everyone can or wants to modify the 7T for whatever reason they have. That's their prerogative.
From what I know, Steve knows his gear, knows his sound and the sound of live and well recorded music. He does great stuff professionally and has the ability and means to do anything with gear if desired. He didn't pursue modifying the 7T, he moved on. That's ok. Your 7T was never disparaged nor commented on, he just commented on a vintage unrestored stock 7T.
Riight Crooner? :yes:
. If people read the very first post :twak: , they would realize I never favorably compared a stock WORN 7t to the 7c.... And in fact agree a stock good shape 7t does not match up to the 7c....although I have a second VERY VERY late serial number ( 1843X ) 7t that is 100% stock ( only a light Di-oxing and all caps & voltages test fine )... Do you want me to back to back test that to my very late ( 2160X ) 7c?
