80's Technics Integrated Amps
I will check the area you suggested and i will return with pictures.
Regarding my previous questions in the initial post let me know what you think when you have time. And thanks again for everything.
I doubt there’s an SVI issue here… this is a 13v / 5v kind of issue…
as for the EQ display, I’d be changing the caps in the FL Display circuit
Added a couple more things from last year
My dad's SL-DL5 is back working with a Shure N92LT (M92LT).
The SU-V9 is working awesomely (thanks Audiokarma!)
Added a ST-S3 (probably going to remove the ST-Z1)
On my office got another SE-C01 to use in mono (totally overkill)
Got a SU-C03 and thanks to Audiokarma it's also working (STK3062 was doing horrible things)
Hi! Can I get more info about my SU V40, SH 8058 (what is the difference between these two 8057), RS BR465 and SL PG300. I'm planning getting a SU V85A to use it as power amp for 150 bucks that is for parts in my area (red bulb is not lighted and no output), what do you guys think?!
Are these BMW E30 rims ?
new member here. I purchased a brand new Technics SU-V8X integrated amp in 1985 from the Navy Exchange in Yokosuka, Japan. It served me quite well until a couple of years ago, when it got a power fault. I took it offline and replaced it with a Yamaha A-S501 (which by comparison, is incredibly disappointing). I still have the SU-V8X, and I plan on troubleshooting and re-capping it. I've read through all 29 pages of this thread, and I'm looking for some hints/tips from those of you here who are more familiar with troubleshooting this one than I am.
a little background on me:
- former US Navy electronics technician (of a sort - underwater torpedo fire control tech on submarines - quite familiar with analog and digital systems), last two years of high school were at a Vocational Technical school for electronics.
- used the old GI Bill (that ended in 1989) to get a BS in electrical engineering
- was qualified once upon a time to do micro-miniature electronic repair
- tools of the trade don't scare me. ;)
I'm chasing down, much to my wife's chagrin when she finds out, a decent high input impedance multimeter and an o-scope, as well as a decent soldering pencil.
edit: I'm amazed at the level of knowledge here, and I hope to tap into it as I wade into this repair and re-cap exercise.
SU-V8X is a nice unit. Is it 100 volts for Japan? If so do you have to use a step down transformer? I have been eyeing an SU-V6X lately. I like that era with the computer drive circuit. They sound quite nice. Best of luck getting it all sorted out.
no, it was set up for 120/240. it is certainly one of the best amps I've ever heard. I drove a set of Cambridge Soundworks Ensemble speakers with it when it was running.
Welcome! Kadena 84-86.
I recently rebuilt an SU-8080 and it's a very nice unit
Ooooo V8X from Navy outlet… most likely a SPA suffix
We’ll start a thread about it… and what it’s doing/not doing… power… safety operation etc
will do when I finally get a few things sorted out first. I have a high input impedance meter being delivered today (Fluke, I need it anyway)), and am consulting with a friend about what o-scope to get. my friend has an electronics repair shop, is well-known in audio circles as one of the best repairman in the biz in central Ohio (Pete Wickham, and some of you may have heard of him, if not, he's on FB - look him up at Wickham Audio). it's not cost-effective to ship him my amp, and since I have a certain skill set, I'm repairing it myself.
where is the best place to start the thread as I delve into it?
Hey I just got a SE A5 MK1 and a SU A6 MK2, do you now anything about this two models. I would really appreciate if you share us info about those two! I heard they give very good results! I saw SU A6MK2 CMOS chips MN6631A are quite peaky and sensitive.
In the Solid State section :)
@SVI2004A
I have an MCS 3842. Made in the early 80s by Technics. A nice unit with discrete outputs. Worked great until one day I muted the TV and when I unmuted the amp had gone silent. And when I look at the LED that is in the center of the LED power meter is also not on as usual. So it seems to be completely dead, no relay clicks or anything. There is a fuse next to the power switch but that appears to be good and I think I may have even jumped across the fuse holder to check things without any positive (or negative) result.
So my guess is the transformer has gone out. It now sits in the closet. Asked a local tech about it and he wanted $150 just to diagnose. That does not seem worth it because...
1) I don't really care for the balance slider that needs to be unsoldered, opened up and then cleaned and lubed. I never did that and it never worked perfectly.
2) I can buy an entire working unit in better shape off of Ebay for about $150. The same as a diagnosis...
To be fair he would have applied that $150 to the actual repair but then again it wasn't worth it...
My guess is that I would need to take voltage readings on one side of the transformer. I have no service manual at all however. The MCS ones are hard to come by.
So maybe I should just say goodbye. LOL. I don't know...
I may in the end just gift it to the tech, but first I wonder if I can learn anything...
@SVI2004A
Technics Xfmrs have thermal fuse In them… easy enough to bridge
If you’re handy with a multimeter we could track the culprit down
