I am looking for sources... not much luck so far.Oh yes 3104 or 3105 - id opt for the 3105 - a lil headroom doesnt hurt
Hi SVI2004A, let me abuse of your patience…Oh yes 3104 or 3105 - id opt for the 3105 - a lil headroom doesnt hurt
Thanks. how about the option of taking the 3104? (note:3104, not 3204) Would it be worse/better than the 3206D?The D was the last run of them … 3206 3206A 3206B were the last of the old runs…
the 3206C and D were in the BC module era…
there were revidions done on the voltage amp stages and the BC modules dropped synch bias
The 3206 chould run a bit cooler than the 3204 as it has larger outputs and will find it not running to full capacity.
‘nonetheless it is important that the fan works properly as the heatsink is not much larger than the power ic
yes, i got that. I am intrigued by the 3206 giving a bit more headroom, but put off by being a D version (cheaper build, no synchro bias)....On par with the 3204 -
last digit is power output
After searching a lot I only found a 3104 to replace my dead 3204.Oh yes 3104 or 3105 - id opt for the 3105 - a lil headroom doesnt hurt
How?5V won’t upset them.. but if you want to wait n search, surely Something will show up…
that’s a cool list of outputs…
send a copy to me… I’ll add to that
Thanks. Is my list merged into it?Made a list of amplifier output stages of Technics Integrated amplifiers… see attached pdf
Thanks for the huge list Baily! Great info...Did it all from scratch… it’s near impossible to import things to an iPad
