My su-v2x comes with SVI2003, so that's fine by me!SVI2003 is better in build quality- they used STK2038IV while SVI2003 was being produced then they ran both on runs to use up the STKs
V1X Only were fitted with SVI2003
A look at the STK and an SVI substrates
View attachment 3191068 View attachment 3191069
I am hoping it's one of the ones with the better IC, I am building a full technics system with these parts, got an SL-7 turntable, and an Sl-p350 to go with it in one of my systems.Oh niice
love the V4X - that is what got me into Technics
I’m sure you’ll love that
I haven't heard the SU-V4X, not sure how it's different, sound wise obviously.Some amazing pictures! How does the cu-04 compare to say the su-v4x? I am in need of a small unit for a project
Yes, the V4X is a great amp! I just got a second one lately, will get it checked out over the weekend. It's a V4X-KEK from the UK; needs some cleaning and checking for dry solder joints, etc. Baily, this one was made in Sept 84 and has the "B" (16) board. Was hoping it would be the "A" like my other one. Will see how they compare when ready to rock.Oh niice
As it turns out, the 2.7v supercaps are fine. All is good and the amp sounds incredible! I had a couple of original A1124 pre-drivers left over from my first V4X re-build to use, but needed 4 total, so I went with the KSA1013Y as recommended by another user. Those and the complement KSC2383Y, to replace the C2631 current stabilizers, turned out to be great substitutes. They both get a bit warm but not like the originals did. A bit more tweaking may be in order, but going to put some hours on the amp and enjoy the music for now! I agree with Baily, this is a special one in the 80's Technics New Class A offerings.Baily, a question about the "Gold" caps C705 and C706; I'm replacing them because both were leaking and one had corroded its + pin open. Original caps are 2.3v.
The service manual schematic shows this value, but the list of components shows them to be 2.7v...which my other V4X has. Is it OK to put 2.7v ones
in place? It appears all they do is hold voltage in place when the amp is off, as they connect to pin 14 of the 7506.
Really? 3104/3105 would work in my amp without any mod? Was it ever tested?Yes the SVI 3100 & SVI3200 series will be fine… 3104 3105 …3204 3205 3206
SVI3000 SERIES (18 pin) have same pinout as STK4191V series - different than 3100 and 3200
Yeah… the early ones were fed from pin 1… but they went on into pin 18Really? 3104/3105 would work in my amp without any mod? Was it ever tested?
Comparing schematics it does not seem the case. For example, the speaker relay drive in the 320X is on pin18, while on the 310x is on pin1
Ok, thanks. Let me see if I can find one somewhere. I run out of options when looking for a real 3204/3205…!it will bolt in and run… no mod needed
