80's Technics Integrated Amps
You got the components in the right spots
guessing you pulled out relay jumper pins
the faults you described are signs you were sent a deceased ic -
while I haven’t had counterfeit SVIs from the bay, the pulls are very hit n miss if they’re functioning
what voltage is on pin 17
Ohhhh what transistor did you put on the relay drive?
if you used a 2SC trpe that may cause problems
2SA992 type should have been used
i used 2SC2389
Pin 18 will be a 0v then ~ 4 secs -14v (relay control)
so my relay is not working as it should? (powers on with thee amp and shuts down about 4 seconds after the amp shuts down)
i used the G2R relay because it was in stock and the one I found on another forum as compatible (G2R-2A) wasn't
I figured I'd just bend the 2 and 7 pins
I'll measure the voltage and get back to you
could you tell me meanwhile if the relay could be the cause of the pin 17's capacitor's combustion?
I'm 300% sure I didn't screw up the polarity (I also thought it is weird that ALL the other capacitors on board have their - looking at the back (inputs and outputs) as well as all the other transistors face the xfmr, whereas the newly installed capacitor and transistor are facing the opposite directions from their brothers. which is why I triple checked their position
so I'm measuring without the blown capacitor
pin18 is instantly at -24.5v, pin 17 is at -27.5v
and I did remove the 2 bridges beneath the relay initially
btw, my ic actually has really weird printing on its case, a kind of mistake the japs could not have made (small s in stereo, capital i in amplifier or second L)
this is what's beneath the case:
it's not from ebay, it's from aliexpress
pull The incorrect drive transistor then check pin 18
possibly this may have been caused the issue… it is never good to npn in place of pnp… that’s generally turbo express for smoke
I've pulled the transistor and pin 18 is at -26v, pin 17 at -29v
so I've fried the ic by using an npn transistor?
SVI3100 and SVI3200 series have this substrate
note voltage amp ic and smaller mute/protect ic in there
The SVI3000 series has the STK4191V pinout
is it any good? ) or should i get the 3102 back?
how many pins are incompatible?
is there a possibility that I've fried something else by soldering this onto my perfectly working up to this moment amp?
other than that I have no reaction that doesn't involve swearing
The 3000 series is entirely different…
that one has a cooked output on its right channel.
pull the phantom 3104 out..l
check resistors around ic
3102 will work with the mods… though bridge relay contact pins (as 3102 doesn’t have relay drive)
later on if you get a known good IC it should be an easy transfer as youve set things up for it (then unbridgeable relay contacts) and the correct drive transistor
If I ever buy from AliExpress I’d have to order a few to check that it’s the right ic internally
that’s as crazy as a STK4241 someone got sent by what should have been a reputable supplier (see pic)
thank you for your time and knowledge sharing. i'd offer buying you a beer or two, but am under sanctions, so paypal and visa etc don't work no more =0)
All good
hopefully sometime you come across the right ic
Lord knows what they get up to in China… its Not a counterfeit… Substrate code SUP29421- probably 1-2
scary they’re changing IC # or cookie swapping front covers -
the SVI3102 is the longest production run IC - SVI3205 wasn’t far behind it - RSN3502 was a A new era SVI3102
All good
i went for the 3104 because it looked pre BC, as I've read in your post in a different topic that they were better.
if I go for the 3204 - should I hunt a pre bc module? there are a couple of them on sale, some have the BC cover design, some aren't.
these Chinese sellers sale fake burnt ic's because they win most of the disputes by stating that the module was installed or by stating some other bullshit. which is why they rebadge them with whatever comes into their mind. i'll be prepared for the next delivery and buy not only from a reputable seller, but also an ic that has good reviews. we'll see, how my dispute ends with this piece of (s)crap.
btw, my local store has the 2sa1145 PNP -150v 0.05А 0.8Wt 200Mhz - could I use that or should I hunt the 2SA992?
2SA1145 will work there
suppliers reaction to any claim
they can crap on till the apocalypse…. NOTHING will change the fact a SVI3001 was rebadged as a SVI3104
OPTIONS for ic for you SVI3104 SVI3105 SVI3204 SVI3205 SVI3206
There are 3103 and 3203 but I’d opt for the larger ones
I have acquired an su-v2x, when I turn it on ,the safety light comes on immediately, however the green computer drive light takes up to 30 seconds to come on, is this normal?
Yeah correct operation stays on 8th flash
then 14secs after, auto illuminates
