80's Technics Integrated Amps
Anybody here that can help me?
Maybe I've not been clear enough.
What I meant, with my previous post, was that in the beginning of this thread there is a discussion about Technics amplifiers with embedded microcontroller.
In such a discussion, it has been told that blown lamps can drive to microcontroller (and then, amplifier) malfunction.
I checked the schematic of the SU-V7X, and found no evidence of this claim; in my opinion, a blown lamp cannot influence the microcontroller behaviour, but I can be wrong and would like to have a confirmation of that.
Hi croccodillo, l am sure someone that is familiar with the SU-V7X will chime in soon. I haven't looked at the schematic but my guess would be that you are correct and the relevant IC pin is a low current lamp driver only.
Uses 11v “grain of wheat” bulb w/ leads... use a 55ma 12V Bulb
will NOT upset operation... it’s just a bulb...
Not sure if your SU-V7X has a similar layout to an SU-V707 but I got the bulbs from an Ebay seller and then posted about the installation here...
https://audiokarma.org/forums/index...vxxx-new-class-a-computer-drive-lamps.779067/
The Ebay seller that I got the bulbs from is projectblk86 and he also sells by the name "Joe's Quality Wholesale". He is very knowledgeable about lamps for audio equipment...
Hello,
In the meantime I changed my mind, since I found a really good sample of an SU-V9.
It seems to be in great conditions, has been serviced about one year ago, cleaned and recapped (the previous owner told me the technician swapped 8 capacitors, I do not know which ones).
The amplifier is on its way to my door, should be here next Monday.
It is a black one, which I do prefer a lot, compared to the silver one (but this is simply a personal taste).
The original owner told me that everything is working fine. We will see.
What should I check, before to power it on?
Icq? DC offset? What else?
Any tip you know, related to this particular model?
Moreover, since I intend to keep this monster for a looong time, which spares should I consider to buy?
Last thing: next thing to buy will be a set of speakers (in the following months, I have to wait my wife "forget" I bought the amplifier).
I would like a pair of Technics speakers, or Grundig (since I already own few of them), or any other good, cheap vintage speakers: what would you suggest?
I will show my new amplifier as soon I receive it!
Hello, the SU-V9 arrived yesterday.
What a beast!
I really love it.
The aesthetic conditions are superb, no scratch neither on the front, the cover or the back; no oxidation on rear connectors; the front need a cleaning, but it is fine.
The glass is still original and intact.
Only aesthetic issue are the switches for speaker selection, tone operation, subsonic filter and loudness that exhibit a sort of oxidation, I don't know how to explain, something like white powder. Any clue on how to clean them (I know that it is the powder coating that is peeling off, but how to minimize the effect)?
Of course I have already conneted it to my system, it works fine, with a small problem: sometimes I "loose" a channel when I move the input selector seitch; I'm using the "Aux" input for my raspberry PI music server.
I think I will need to clean the switch on the input selector board.
It is the uppermost one, and I know this is a common problem.
Also the bass/treble potentiometers scratch a little, when used.
Those are not big issues, nothing that a good cleaning and an abundant dose of cleaning solvent cannot cure.
Any suggestion on which product could I use?
I have another doubt, however; the amplifier is arrived to me with the main input set to 220V, but here in Italy we have 230V; I think the previous owner didn't use the amplifier for a long time, because a long ago the main voltage was 220V.
Yesterday I ran the amplifier for few hours; and in the end the transformer was quite hot, maybe too much; do you think it would be better to set the input to 240V?
Is this normal?
However, the amplifier is great; connected to my turntable sound magnificent.
The turntable is nothing special, it is a quite good "House of Marley Stir it Up", which has a direct cartridge (MM) output.
The turnable is a gift, and actually I like it; its sound is quite good.
The bad thing is that I realized my digital setup (Raspberry PI + E9023 I2S DAC + FLAC collection on HDD) is not on par nor with the amplifier and nor with the turntable!
My next step will be to upgrade my DAC.
The amplifier even revived my Grundig Super HiFi speakers, that are quite difficult to drive: the SU-V9 seems to have no problem to make them sing.
https://audiokarma.org/forums/index.php?media/albums/technics-su-v9.1767/
Hi croccodillo, glad to hear you are enjoying your SU-V9, no doubt a very nice amplifier. The only thing l can recommend on the pushbutton switch covers is to clean with a white magic eraser sponge (and a little dishwashing liquid/water), you will very likely still be left with a slightly tarnished cover though.
Hi all. I am a Technics fan (saw them as a child in my rich friends homes in Romania but never could afford them back then). Unlike you, I know nothing about them and their inner workings.
I own for several years a Technics CH900 minisystem with the SB-CH900 speakers. I'd like to know more about it, but as I know it was incredibly expensive back in the mid 90s (over $1000) and even today it sells for big money, if complete with speakers and running. I am happy with it, but since I moved to a big house, I'm thinking of bigger speakers and more power to drive them. Technics only. Was wondering if you could recommend any Technics amp that would have optical inputs and maybe a remote as well? Anything reliable out there and worth getting or should I stick to 80s SU-V series? What about decent Technics speakers under $500?
Thanks a lot
These are all Technics amps I know of with optical input and remote control:
  • From around 1991-1993: SU-X501, SU-X502, SU-X520D, SU-X901, SU-X902, SU-X920D (all part of midi systems and only remote controllable with the matching tuner)
  • Relaunch (since 2014): SU-G30, SU-G700, SU-G700M2, SU-C700, as well as the SU-R1 preamp and SE-R1 power amp
Amps with optical input, but no remote control (all vintage):
  • Integrated: SU-V90D, SU-V100D (Japan only), SU-MA10
  • Preamps: SU-A60
  • Power amps: SE-M100
No idea about receivers; never cared for them.
In terms of speakers some good candidates might be the SB-M300, SB-C450, SB-EX7, or more vintage ones like the beautiful SB-5. I've never heard any of them, but I have siblings to the latter and am mighty impressed.
Thanks for the reply. The V90D looks really good, but a little hard to find. As for speakers, SB-C450s seem to have good reviews, but I'd prefer something with a 25cm woofer.
Good devices are hard to find and require patience, there's no way around it (unless you are willing to pay ludicrous sums for certain offers that are readily available).
25cm woofers are less frequent among later models of loudspeakers, as Technics, like others, have transitioned to slimmer designs. Your best luck then might be in the 70s, with models like the SB-440, SB-X5, or the 80s (SB-6, SB-M5, etc.).
Hi there!
this thread may be a bit old but i have to thank you all a lot for all the Infos on the SU-V4X! ;)
I have 2x SU-V3 and was really amazed by this solid performance. So after all the Infos here i found a nice silver SU-V4X with a silver ST-610 tuner.
Right now it is gone for service to a friend that also changes the speakerscrew things that break all the time.
Well it sounds amazing indeed! Here with some Philips rh 438 speakers
best regards, daniel ;)
Wow new ones! ;) i was really happy to get my silver one and getting some proper speaker terminals on it.
The guy thats doing this got me hooked on SU-V3 ;) .. its a damned good amplifier! I have some AKG K340 headphones hooked to it and they sound amazing good on this amp.
So big thanks for the tip with the SU-V4X Amp SVI2004A !! ;)
Technics made some very nice equipment in those days. Only caveat is that they don't like being driven really hard -- on the computer controlled ones the STK will fry and on the others I've seen the voltage control transistors un-solder themselves from heat.
If you recap any in the SA-120 to 410 range ( single STK running both channels) and have 10uF 16V caps coupling the tone controls, replace them with non-polar ones. Every one I've had presents with those caps leaking onto the board and in very poor shape except the SA-180 I'm currently working on, and those were non-polar. I'm going to go back into the others and put non-polar caps there.
The STK20X8-II series were a bit temperamental and not all that robust - especially over time - STK8050 also were known for this.. the STK20X8IV were somewhat more reliable…
So, my beloved SU-V4X has died. No more of that Iovely great sound coming out of my speakers. No sound comes out of the headphone jack either.
Now, when I turn the unit on, first the class A logo light up and the the right orange "safety operation" light starts to flash, then after around 5 seconds or so it stays on. After about 30 seconds, the left "auto computer drive" light (green) turns on, but I do not get a click from the relay.
Previous to that, I would sometimes get a louder crackle whilst playing music (one only, like when you connect a speaker wire and the unit was on), through the speakers, but it would either
a: continue playing, or
b: it would shut itself off.
If case b, then I could turn off the amp, wait a couple of seconds, then restart it normally and it would continue to play as if nothing had happened. Alas, this is no longer the case.
I bought the unit off the bay from th UK around 4-5 years ago, after getting more than one recommendation for this unit on this site, especially from @SVI2004A. It replaced my busted SU-V4K and I really loved the V4X 's performance. Much better than the old V4K.
I'm not much of an electronics guy, though I do have a good soldering iron and meter.
Can anyone help me out and give me a couple of pointers as to where to look?
Thanks
Thanks Baily. Will have to check the relay area. BTW- it turned on again earlier this evening and ran as if nothing had happened. Strange, as it hasn't started up for like 2 months... it probably knew that I needed my Floyd fixxx...
Also started to go down Baily's rabbit hole- just bought myself another SU-V4X black to go with my stack. Was listed on the bay right here in Alberta, Canada for just over CAD200.-. Now I will have a spare. But no, am not even considering starting a collection like yours.
