80's Technics Integrated Amps
Hello to All,
would the BC Svi3205 series compatible between A B C D suffix? I got a Bc svi3205 b on my su v909 and it’s most probably defective, I found a brand new BC svi3205c but I cannot find a data sheet to check compatibility, can you help me?
Thanks
I found a BC SVI3205C instead of B not that cheap but still from Sanyo and new.
I will try to change it and see
Shall I consider a plug and play substitution right?
Thank you
Hello Again,
what is the best thermal grease that I currently can purchase to replace the original for the svi3205?
Thank you
regards,
Hello,
I changed the SVI but it didn’t solve the issue.
maybe someone here can help me.
The problem is that I have the right channel clipping with meter all the way right like pulses and sometime the operation led disappear and re appear by himself
very frustrating, I changed the SVI but nothing
Maybe the voltage amp?? It is doing that with and without source and load
Helllo all,
A new user here.
My name is Giovanni, I write you from Italy.
I owned few models in the past (all gone, I needed money); I currently only own a Technics SU-600, given to me by a long-dead friend, which I don't want to give away.
I also own few vintage loudspeaker, like Braun (L620) and few different Grundig Super Hi-Fi.
I'm writing here because I've been offered a Technics SU-V7X, a very nice one, very well kept, without hiss nor cracking sound (so, switches and pots should be fine).
The only "problem" is that there's no light on the "New Class A" logo; that means the lamp behind it is blown, I suppose.
The strange thing is that everything seems to work fine, even without lit logo.
So, I downloaded the service manual from Elektrotanya, and gave a look at it.
I suppose the lamp is the one labelled "PL801", on page 32 (please let me know if you need the manual).
Now, I'm an electronic engineer, specialized into embedding programming; but I really cannot understand how the lamp (if I'm correct in identifyng it) can alter or change the microcontroller behaviour; it is connected on an output pin, throught a transistor.
Is there anybody that can explain it to me?
I'm asking because if there's no influence from the lamp on the microcontroller firmware (as I think), I could replace the lamp with a string of yellow/white smd LEDs, and forgot about the lamp blowing in the future.
Thank you for your assistance.
Regards,
Giovanni
