80's Technics Integrated Amps
I was wondering about the mainboard differences between the 17 and 16 versions. 17 is the first run, correct? What did they change?
May have been more poles on the switch i glanced at the one in my amp at the time, and wondered why they just didnt use the switch thats acommodated for on the main pcb... the switch only needs 6 connections - hi tap, lo tap and output to main pcb... wonder if there was a switch supply issue...
the 11vac winding is not adjusted
There were slight component location changes..... just revisions i guess... but there is a magic in the A run type... spesh if it has that internal sound... its hard to put a finger on it, but theres something there.
more interestingly is how they stocked the pcbs... the runs switched over a few times.... ive seen some mid 85 amps that went back to the A type... seen V4X amps produced mid 86 still
Yes, the details get interesting, if you're prone to "go down a rabbit hole" like I am sometimes. I'll have parts in hand this evening to work on my V4X, at least enough to test it's operation. I'll might even get far enough to test the "singing module" phenomena! That has to be some kind of mechanical resonance with the outputs and the A type board (17). My amp had some damage in shipping, and I had to remove the transformer mounting bottom plate to straighten it...so I may have disturbed whatever chassis condition and board mounting that promotes the resonance. Also, when I removed the tone board, there is a cap (C304) with a plastic sleeve glued over it, which extends down to the mainboard for support, or maybe damping? Seems unnecessary to the tone board, it's fastened by a screw and all the control shafts to the face, so should be stable. Wonder what that's about...
Hopefully all pans out well... saw the scone on the right hand rear of it... yeah sometimes packing isnt up to par... and the weight of the xfmr can wreak havoc in poor packing
keen to hear how you get on
Here's a pic of the impedance switch, SU-V4X-KM with the high mount switch assembly; it appears Technics had Alps make another switch,
with the larger body on the end, to which the transformer connections were directly soldered. Hard to see in this pic, but directly below the
switch on the mainboard, you can see the green sideways "N" stamped onto the area where the normal switch (grey portion above) would
have been soldered into the board. And the line of transformer lead attaching holes just above. The ground wire is soldered there, and the
others are soldered to the bottom of the brown portion of the switch. I measured the grey section for continuity, and it is functional, just not
connected. I'm wondering if the Canadian electrical certification required the larger format switch. Just a guess...since the larger switch
wouldn't fit on the board, they placed it higher in the cabinet. Underneath the board, all the traces are still present, with the wave soldering
filling the holes.
Yeah that could have been the case... only japan canada and usa got them like this... tho PA suffix (US Military) was on the standard setup
I got the V4X running last night, and all seemed good listening to a CD through headphones for about 30 minutes. Then it went into safety...so further investigation is necessary to find the trouble. All parts are still original, except for the gold caps and relay which I replaced before powering up. Prior to powering up, I resoldered all the discrete transistors on the mainboard, the ribbon cable headers, and the ICs, being extra careful not to bridge any leads. Cleaned excess flux with IPA and a toothbrush. I have ordered replacement A1124 and C2632 just in case, already have on hand A1015 and C1815..how should I move forward to find the problem? Let it go into safety again and look for voltage irregularity? What would you suggest is the next likely failure area? This unit looks low hours, I didn't see any sign of darkening or heat related fatigue like I usually do with units having a lot of prior use.
Do check joints on Q501-504 often these can do that after the heat expands things.... also resistors associated with them
be careful of new transistors fakes, of these do exist and results are not pretty
A safe area to check output is R539(Lch) or R540(Rch)
easy spot to use hook type meter clips or use standard leads as risk from slip is less
at least we can narrow it down to 1 channel
when in safety operation, does it reset straight after cycling power?
it may well be imtermittent DC pulse from pre drive stage
Okay thanks...I did reflow the joints on those transistors before powering up. Will do that on surrounding resistors as well. I have some replacements coming from a trusted source (A1124 and C2632), and I can test them for gain and current before installing.
I did not try to reset it immediately after it tripped into safety, so don't know if it was a spike that triggered it. Will repeat testing this evening...
It did sound great while playing! Very clean and clear, all controls working, no background noise. Good bass extension, as you've noted.
Thanks for the help!
Sounds like youre ontop of it all... it could be a 2SA1123 going open which will trigger safety operation grom -V dc...
hopefully the new transistors are 1st class and quell the spike... the 1124/2632 have better power dissipation which helps keep heat down
While I'm waiting for parts to arrive in the post today, here's another amp I just obtained from an auction site. It's a 1986 SU-Z900, which is the same as the SU-V75 internally. Both are US market amps sold usually as parts of a system; the V75 has a New Class A badge on the front, the Z900 does not, but both typically have SVI3105 modules. I've got several of them already. They sound very nice, and if you can forgive the BPC presentation, and just enjoy a 100 wpc channel amp, you've got a bargain! So this one was damaged in shipping, face broken beyond repair. I have a V75 that needs a heat sink assembly transplant, and this Z900 may be a donor since it's not presentable any more...so upon opening it up, this is what I found inside:
My delimma is, should I harvest the heatsink, or try to listen to this 3105C BC module first? Someone obviously removed the original SVI3105B and installed this one. The amp is
supposed to work, but I haven't powered it up; it's got some loose mounts and I think it's missing a ground strap to the chassis. But it's my chance to actually hear a 1990's BC module
to evaluate it's sound, vs. the real 3105B. Hmmm...what to do...
Did the later BC still have all the functions, synchro bias, etc.? Just cheaper components? I recall you saying they did away with pure copper traces in favor of alloy, different resistor composition, etc. but I may be mis-remembering.
IMO SVI2 was the b0mb.... pure DPP
SVI30XX was akin to STK4121 series -> STK491V bit pure complimemtry symmetry....
3100 and 3200 series habe same function in centre 14 pins
Ah okay, thanks...I think I'll prove this mutt amp runs, just to make sure the board is okay if I need one down the line. Give it a quick comparison with a nice V75, just for the comparison of sound quality. Then part it out and move on. I got my spare transistors for the V4X, so that's first action for the rest of today! I really want to get that one stable this weekend, then put in the main listening rig where it can work a little harder.
Onc setup, the V4X is awesome at long duration crank ups.... be sure its pure level or sligjtly RH up - (volume side) to keep coolant behind power ic
Ok yeah that makes sense about the heat pipe. That may be what happened to the V75 I have, someone ran it on end or something, because the end near the power IC ruptured and the refrigerant escaped. It still works ok if you keep the volume down to normal levels, because the aluminum "wing" on the heatsink dissipates heat pretty well. And I keep a small fan on it...but it'll be right when I get the heatsink transplanted from this Z900 into it!
