80's Technics Integrated Amps
Indeed it is a nice scan, alas it is only the schematic! I've searched the web and I cannot find the complete service manual.
That's interesting...the one I downloaded from hifiengine yesterday is complete. It's English/French so a couple of pages might take some interpretation. Try it again, if you haven't...or send me a PM with your email and I'll try sending it to you. It's about 5MB PDF.
Okay thanks...I tried searching for the Technics part#, no luck so far. If I substitute them with an equivalent Ma rated bulb that should be okay?
yes, theyre connected to the 11Vac winding on xfmr, recommend the same mA as then the illumination chamber wont get too hot
Yes, noticed they are powered from the 11VAC winding, and the lens looks a little brown from the heat. I found some 35ma ones, so may try those if I can't find the 55ma. Maybe dgwojo has some, will ask.
All of the 84/85 lineup do... Z400 Z600 etc use same bulb as that for display panel... alot of amps/receivers used these... think the Late 70s V2 / V4 etc used the leaded bulb... the SU-V909 was lamp critical, as the new class A lamps formed part of the power supply for the compiter drive section
I just tried it again and it is the same. I am trying to find out how to s
I found the manual for SU-V4A. I hope it is the same for SU-V4. Thank you for your help!
I apologize, just now realized you needed V4 manual. Be careful if the adjustment instructions don't appear to apply to the V4 parts you see internally. Maybe SVI2004A can chime in?
Okay that's good info. I was thinking more models would use the same part. Dave at dgwojo has some, got them ordered. I'll let him know that it's common for Technics; as I have time I'll consult the various manuals I have and check the OE part# listed.
Thanks for the notation on the SU-V909 being critical...
My V4X has the "17" board version.
Niice going, theres something about the 17 pin (Earlier A type) version that sounds alluring
With the serial you can identify what day your amp was made
I was lucky enough to get this gem... SPA suffix (US Military) multi voltage - this is new, new in the box and has a very rare (for this model) green new class A decal.
It is the A type pcb - saw through the vents.... not a speck of dust in it or on/behind it.... funny thing was the seller listed it as a SU-V98 new in box.... had to fight off a few bidders
this one made 11th June 1984
3203BD3A-335F-4334-AB96-FA0CEEDE8308.jpeg 39A5706B-90AB-4B9B-9422-3045D58D1D95.jpeg 680B2C02-1B46-4CA7-9554-AF4E8967FA46.jpeg 2301F0A8-7023-46F4-B15E-340701531D7A.jpeg B628F24C-A467-4BB2-B366-DD05A33E75F3.jpeg
Some of the A types have this interesting phenomenon - you can heat the amplifier w/ speakers off.... kinda sounds lile the needle on a record
can be seen/heard here..
View attachment 1932194 View attachment 1932195 View attachment 1932198 View attachment 1932199 View attachment 1932201
Wow! That is incredible...I think I remember that listing, thinking V98...but no! It was the V4X! Glad you were able to score it. A very unique find, indeed. That was a few years back, if I recall correctly. But my timeclock gets wonky most of the time. Lol!!
Checking the serial number on mine, it was made in same assembly plant, on June 25.
Strange thing about the green Class A, I have a SU-V9 that has multi-voltage trans, and I think it's green also. Pretty sure it was an English or Scandinavian market one. Can't check right now, it's in storage.
Was Feb 16th 2019 :)
i rememver i got 5 V4X amps in just over 2 months around that time... most from the UK (EK) also got 2 black ones in box
Konw what youre sayin of timeclock... i find it all a tad hazy... email is helpful to see when auctions were won
Stereo71 is your V4X silver or black? what region was it?
looking forward to you hearing it!
Mine is black, it was sold in Canada as far as I can tell. Notice back panel only has a serial# tag, no model ID:
I have one of those... KM version - was in japan usa and canada... i got one from yahoo japan... that region model (god knows why) has the speaker impedance switch (Tap select) on its own pcb up higher whereas the rest have them on main pcb (sw usually down bottom area)
Ah okay, I wondered why the impedance switch had it own board. Also, it has another unused switch in the assembly. Any idea what it was intended for?
