80's Technics Integrated Amps
Oooooo
They missed one....
C410 (lower corner) would too have been changed- mild change in this set for NFB loop
Oooooo
They missed one....
Ah yes, I'm sorry...it's not detailed in the diagram, but it's shown in the list of affected parts. So the change from 4pf to 8pf adjusted the feedback. Thanks Baily!
Back about a year ago, I posted re some issues on my Technics SU-V4K (Post 229-231).
I've looked over the PCB from both sides, but have not been able to find a loose solder joint. I used DeOxit on the switches / pots (sprayed it in through the little openings
Unfortunately, today the right channel dropped off and I no longer get sound out of it. The LCD meter shows no activity on that channel.
Doesn't matter which input (AUX / Tape / Tuner) I use, there's no sound from the right.
So... I've opened it again.
The two little fuses next to the relay are good. The amp still makes the 'click' shortly after I turn it on.
How do you remove the plastic cover over the relay? I would like to check the contacts on it, but am reluctant to just pull up on the cover etc. for fear of possibly damaging it in the process.
I took pics of the main & side boards a year ago and again today. I'm not seeing anything different. A little dark spots under a couple of transistors ( Q314 & Q316 ) and under R375, but I don't believe it's anything major. I think the spot under the resistor is from heat during the installation, as that one is physically larger than the one at R376 and the solder joint doesn't look as nice as the others.
I've had the unit since new, summer of 1981 (!) and it has never been services, so it is still un-adulterated, except for my contact spray cleaning.
P1200902.JPG P1200893.JPG P1200894.JPG P1200895.JPG P1200896.JPG P1200897.JPG
View attachment 1332575 View attachment 1332577 View attachment 1332578 View attachment 1332579 View attachment 1332580 View attachment 1332585
If it was my amp, I would just change the relays,
once they start making trouble they never stop.
OK, I checked both of the little fuses near the relay and these are both good.
I was able to open the relay today after getting over my angst to do so... cleaned both of the contacts. It appears to operate just fine.
I found one solder pad connecting R375 to TH301 had lifted from the PCB, along with the components. I resoldered these two together, so I don't believe there is an issue here anymore. Guess that's why it's black under the resistor. I would say this is on the Left Channel.
I was then able to do some "Troubleshooting" as per the SU-V4a Service Manual, using my Fluke27. Hope I'm measuring it correctly (DC mV).
Clamp Voltage L channel TP301-TP303 (negative probe) was 0.7, was able to adjust it down to 0.5 as per the procedure. ICQ L channel then adjusted to the correct clamping voltage of 15.5. Both readings were relatively stable.
When checking the Right channel, there is no post on TP304, just a pad. Hope this is correct. Clamping voltage is all over the place, both negative and positive mV, doesn't matter where R338 is located. As such, there was no point in trying to adjust the ICQ, as it also all over the place.
Guess I have a bigger problem somewhere....
Can't figure out what the other TP 's are for as the "Manual" doesn't really go into these.
Hello guys,
I'm a new member of the forum and i would like someone to give me his lights about my mini HI-FI. It's a Technics SC-CA10 system (around 1996/97 EU model), with SE-CA10 Amplifier (2 X 70W 6ohm). By following the discussion about the Power Modules, i checked mine and has two BC RSN3502 A, one for the main channels and one for the Surround i guess. Is it any good and generally whats the standing of this system. It is in perfect condition and the looks is amazing in my opinion!
The reason it came out of the closet is some Dali Zensor 3 i bought recently. It sounds good on them. Originally came with some Technics SB-CA10 (i guess around 2 x 50 W at 6ohm with 89dB sensitivity) made in Spain. Very low quality for this amp. I just kept the cabins for some project in the future..
Hello all, i just read with great interest through most of this thread. I have a Kenwood(Trio) KA-9100, and was given by my landlord his SU-V8X. His thing switches on fast-blink on of the protector occasionally and i told him i'd look into this and upgrade all the ageing parts while doing so. Before starting work, i hooked it up in my setup and Wow -- not bad at all compared to that Trio legend. My KA-9100 has seen the pwr amp section fully upgraded (new RN60/65 resistors, and perhaps more importantly, new 'lytics. I used a mixture of UZL, Silmic/Silmic-II, FC, FM, FR, PM, 601D, UKA, EKM to do that job. So all that's nice in 'lytics from all over the world to avoid one single "sound" to dominate. I offered the same update for the SU-V8X and did it on all sections except the vertically soldered board with the bias processor on it -- the connections to the main board seemed "difficult" to properly unsolder/resolder. So i skipped it.
Also changed the 8200uF/80V main caps to 22000uF/80V that are 40x82 instead of 35x80 (i made a mistake judging dia when looking though the top grille). Just possible with a bit of bending on the cap terminals and reversing upside down that metal bridge holding the caps on their far ends.
Now, when switching on though a reg transformer, all seems normal, with protector light after a few sec a constant "on" (i know this funnily indicates "all good") and the green light for the biasing also on after another 5 sec or so. Problem is: left channel is quiet and if i turn volume up enough, there's an occasional "shout" of music, then quiet again. Happens the same on LP or CD or Tape replay. Also "Straight DC" vs tone control doesn't matter. The schematic says there's three feedback loops but i'm afraid of unplugging the "Differential amp, ..." board. Checked all diodes incl the two ea. in all transistors both ways round and found no issue bar one: D311 (a Germanium diode) conducted in both directions, measuring 0.326V forward but 1.46V reverse on the diode tester function of my multimeter. Thought i'd found the culprit. Changed it to equiv type on both channels (i.e D312 also). All the same. Wonder what went wrong during fitting of those caps (i did not yet change any resistors yet)
Any ideas?
Ralph
I would spray down all the switches with some plastic safe contact cleaner and then follow up with some deoxit you'd be surprised what this can do with intermittent audio. Even if you've sprayed before I would try it again as thoroughly as possible. I have brought back audio that was still cutting out with just one cleaning. Once, I even replaced perfectly good relays only to find dirty switches continued to be the culprit.
Not related to the problem with the amp, while browsing i believe i notice the SU-V6X and the SU-V8X are identical the first third of their depth (or quarter if you measure innards only). This means, front plate, all tone controls / turnover circuitry, speaker switching, balance/volume/attenuation/loudness and most importantly, the V8x's sweet-sounding phone stage should be identical on the smaller version. That said, the phono signal goes a long 30 cm of cable tighly packed in paralel with lots of other cables before seeing amplification just behind the top right of that front panel. Other Matsushita designs of the time bettered that, for example the SU-V4X praised here earlier...
Try wiggling each knob or dial with music playing. If you can cause the sound to cut out (or in) while doing this, then you know it is a switch/ dirty pot issue. Try and rule this out first as it is an extremely easy test.
Thanks a lot, hadn't thought about that at all as possible... the fault came while just working on it, no delay time-wise. The relay might really be the problem. I just switched all switches plenty of times, turned all pots all their full angles at least a dozen times, and no change. Also tried to "stimulate" that relay by working on/off through several cycles, but maybe i better open it and clean the contacts properly. Thanks for the hint -- Ralph
If you can access relay contacts, spray some thin paper strips w/ contact cleaner and push them in between metal relay contacts to remove oxidation. You should clean relays before replacing them.
Great info, hope this relay can be opened -- will see tomorrow, approaching midnight here. Would have loved to hear that thing on both channels, with just the right channel playing (i believe after brief trial) it already gave a more beefy sound than this morning before the mod. But one channel only, so maybe misleading, and it sure sounded beefy before i even touched it ...
Hey guys, I have an SU-V909 that I've had for several years, has been great to me (after cleaning the input selector a couple times) and sounds fantastic, but has recently developed a problem - wondering if any of the experts here have some advice to narrow things down. Symptoms as follow:
When you first turn it on (cold), the audio comes through the left channel very loud and clipping (not loud enough to be power amp clipping, but somewhere in the preamp) and nothing on the right - if you turn the balance all the way right there's a whisper at most, centered yields the heavily distorted and much louder than usual on the left channel. This occurs on both the Phono and Aux/CD input (which are all I have hooked up at the moment). If there is no signal, there is some noise/hum from the left channel, right stays quiet. The volume control is still effective; doesn't matter if I select "via EQ" or "DC". The Muting button does still quiet it down some but the clipping persists.
After the amp has been on for 15 or so minutes (regardless of if it's playing music or not) and is getting to be warm, a solid smack (or three) to the top of the case resolves this and it goes back to sounding great. It will continue sounding good until it's powered off and cools back down, then distorts when you turn it back on cold and so on.
I have the service manual, but this monster is way outside of my expertise in equipment repair (I mainly do tube stuff). Any suggestions on where I might look first to find a bad solder joint, bad connection, leaking cap, or anything along those lines based on the above? I'd really like to get this system working reliably again.
Whacking the top case..... after warmup..... this is screaming dry joint(s)
Try re plugging the connectors to start.... but gently tapping front end pcbs and drive pcb may help you narrow down its location (use plastic stick for this)
Today I had time to take it down to the bench and do some investigation, naturally I powered it up and it sounds fine :dunno:
I listened to music through it for about an hour and turned it off. Once it's cooled down I'll try again. While it was on I used my Electronics Poking Stick (definitely not just a small dowel rod) to tap around to see if anything acted like it had a cold joint or was otherwise mechanically faulty, no result, everything seems normal. As much as I'd like for it to have fixed itself, I'd rather find a 'smoking gun' and know that it's been fixed, and not going to start doing this again at random.
(No it isn't connected to that little Numark, there are a pair of cheapo RCA bookshelf speakers under the bench)
Persistence will be the key just leave running while you look at other things... there’s nothing as annoying as an elusive dry joint
