80's Technics Integrated Amps
Oh yeah... the tone board is not looped through output in the V8
Hi SVI2004A, It's been a while since reporting on our V8 refurb. We replaced almost everything! I can show you a photo of all the parts if you want. Finally got it running after replacing a resistor in that top front end board that was off by a factor of ten!
It ran and sounded OK but the DC offset wandered constantly from -500mv to +500mv! Nonetheless we ran it for hours and sounded better as all the caps, ICs and transistors etc broke in. We finally got 4 replacement Filter caps for it that were identical to the original in specs and size. Hard to find! Digikey had them. Well, put them in last night and WOW what a difference! The DC stabilized and is now just wandering from +/- 25-30mv. The sound is Stellar! I think it sounds better than the V4X which is saying something! We would have replaced the Main filters sooner but had trouble finding them.
Thank you again for your advice and assistance. My growing collection of these fantastic Technics Integrateds now included the V4X, V8, V8X, V9, and a V76 to run the computer sound.
Best Regards from Texas!
Oh nice.... touch wood I haven’t had any cap issues with my amps...
You have a very good collection there... I’d be hunting spkrs for them lol
Thanks Baily. I've got the speakers covered. Infinity, Advent, Polk, and Jamo. The Technics all sound fantastic through the 6 ohm Infinitys, I have the whole Crescendo series.
Going to replace the big filter caps in the refurbed V9 today. More as an experiment to see if just that will yield improved sound.
The V9 sounds great but I'm a believer in replacing 35+ year old electrolytics before symptoms appear.
Can you tell me if I can substitute Sanken SA1187 / SC2838 ouputs for the original SA1170 / SC2774 in the V9 if needed? I can't find any info online.
Thanks again.
A1170 / C2774 were superseded with A1494 / C3858
Get them while they’re still about...
Thanks for that, I've ordered 4 sets of the 1494/3858.
Does that mean the the two sets of 1187/2838 I've bought cannot be used in these machines? They were much pricier than the 1494/3858s )-:
The V9 had a noticeable bump up in sound quality after replacing the original main filter caps. I think it's $25 bucks well spent!
What's your take on the V6 versus the V6x? I know the X has the "computer Drive" and rated at 30 watts more, but any other real differences in design or outputs, any recommendations?
Thanks again for your help!
⚠️ 1187/2838 are 150V 12A 120W (same specs as original V6 / V8 amp outputs) though fast at 60mhz
1170/2774 and 1494/3858 are 200V 17A 200W (I fit these to all amps unless I need higher voltage (A1295/C3264 230V))
V6 and V6X are both good amps... I have both... not yet directly compared them.
The V6 and V6X both use 120W outputs at 12A - V6 has more SOA - V6X has higher rail voltage on high tap (8 ohm) 66v
On V6X 4 ohm tap performance between the 2 should be on par V6 @ 48.5v vs V6X @ 50v
I prefer the layout of the V6 - but the V6X has computer drive- both have synchro bias
Thanks again Baily for your very helpful information.
I got it sorted now...(lots of grey hair, getting dyslexic lol, I had put the 1494/3858s in the refurbed V8 last month as per your recommendations and still had extras....oh well)
I'll put the 1187/2838s in a V6 if I get one of those in the future.
Kind Regards from Texas.
Sweet as :)
Nothing wrong with having spares! (Spesh since they’ll all soon be unobtanium)
You have a great setup... the V8 ought to be bulletproof now... I’d imagine only having to keep the input selectors clean.
I often wonder why the SE-A5 never got dual xfmrs like the V8...
Enjoy the bliss :)
Hi Baily, Well that was a prescient comment...I scored a very nice V6 and it arrived with both the Rec Input and the Sel Input cable/switches broken/frozen. Upon careful inspection there was a kink in the metal cable where someone must have really forced it. The other cable came disconnected at the faceplate switch and would not budge more than a mm. Fortunately the sliding switches on the vertical board were still alive after a Deoxit bath. I manually slid the switch into position and the machine came to life. After clearing a lot of crackly distortion in the right channel with Deoxit I am amazed at the sound quality of this unit! I am on the look out for spare cable assemblies and will try to buy a "parts" unit for this.
Are these cables mostly the same length throughout the series? Will a V303 serve this purpose?
So now I have the Sankens 1187/2838, that will go into this unit when needed, but for now I'm leaving it alone as it sounds stellar. Maybe a new relay and new filter caps...
As an old Conrad-Johnson and other high end gear owner that completely missed (and dismissed) '80's "consumer" gear, I thank you for showing us the light..(-;
We compared the sound of a relatively stock V9 to a very pricey McIntosh 7270 amp hooked up to a very decent preamp and the V9 hands down sounded better... amazing...
Regards
Awesome to hear Guilaume57... I am a staunch believer in pure complimentary symmetry, direct coupled output.
The cable lengths should be similar in those units... Technics had the precept of minimising signal path.... source select and rec output were all located near the connectors leaving the feed signal coming up to the volume pot / front end (for higher signal/noise level)
V2/V4/V6/V8 (78-81) and V3/V5/V7/V9 (81-83) also carried into V303/V505/V707/V909 (83-84) - which other than computer drive addition, was a carry on of the V3/5/7/9
A thing to note is internal length - count of positions / degree of rotation/ stop points - which the 3/303 5/505 7/707 9/909 should be replica. Have not directly compared that series to V2/4/6/8... will look into it though - maybe worth comparing part numbers.
I am using an SU-v75 as a pre amp for my Yamaha receiver which does not have phono inputs, except it seems like I have to turn up the volume way too much for me to get to the same level I get out of my CD player. Anyone know how much power the Tape 1 output can supply? I can’t find it anywhere across the internet, although I’ll keep looking.
Thanks!
Hi SVI2004A,
Question about SVI3105, and A,B variants. I have several 86-87 integrated amps that use this amp module, can you tell us what the differences are? One of my repair manuals states there was a running change in the 86 models to the 3105A, and I have another amp (SU-V76 1987 production) that uses the 3105B. Just curious, all the amps run and sound great.
Thanks again Baily. We've got it sorted. Mixed and matched some different cable lengths and wound up with a longer six position switch in the "Sel Input" slot which has normally 5 positions but the end result is a workable very nice running SU-V6.
Another question please, seeing as how the V6 has the same output transistors as the V8s, can we also replace those outputs with the Sanken 1494/3858s or is their a voltage problem?
Your help is very much appreciated, and my Technics Integrated amp collection is growing..(-;
Good to hear you got through the cable issue... not the easiest unobtanium to find...
A1494/C3858 is my go to for the V6 amp too (would be for V6X too if it had the room) and some of my V8X amps are on them too.
Hi SVI2004A,
Revisions were minor - one in voltage amp section and one in protect/thump/dethump - SVI3102 also saw these revisions as did SVI3101... SVI3103 was a smaller run of ICs and it’s 1st revision (SVI3103A) was a BC module (91/92)
Yeah late 86 the A versions surfaced and late 87 B versions surfaces.. though with 3102 I see them mostly appear in 1998 (stock pool change)
The B versions stayed around from 87/88 through to late 91/early 92 (BC module era)
Okay thanks! I have the service manual for the SU-V75(Z900) and it mentions a running change to the 3105A, with one capacitor changed from 4pf to 8pf. All else remained the same as with the 3105 plain. The V75 also had a ruptured heat pipe, can't figure how that might have happened, unless it was run way too hard for way too long. But the module is fine....found a new spare for the heat sink, it's been ordered. After that she'll be good to go!
I appreciate the info!
Thanks, good to know!
Regards from Texas
Where was the cap? - what was it connected to?
