80's Technics Integrated Amps
Yeah, I've chased some nasty ones before. In this case, I've never had it go from "sounds good" to bad, once it starts working right it has always stayed good... until you shut it off and fire it up cold, so there's that. I'll keep trying! It's like setting up the choke on a carb, you only get so many chances a day for a completely cold start :)
Hi
Am looking for some thoughts/advice.
I have an su-v2x hooked up to an sl1210 and monitor audio speakers which I love the sound of.
but I’ve been thinking for a while of upgrading to an SU-v4x which I know are well regarded.
so the big question, will I notice a difference or should I look at something higher up the range
(su-v6x)??
thanks
I wondering if somebody knows what is the difference between the SVI30XX , SVI31XX and SVI32XX families; User SVI2004A wrote SVI3204 , SVI3205 and SVI3206 are compatible, how about with other SVI families like SVI30XX and SVI30XX ? are they fully pin compatible and fully interchangeable? I have some svi3004 svi3104 and svi3204 ICs unfortunately lack of info regarding the SVI3004 thanx
SVI3000 series is same pinout as STK4191V
SVI3100 - SVI3102 (14 pin) forms the centre 14 pins of SVI3103-3105 and SVI3200 series
As you see in this pic... I went from 3102 to SVI3206 (pcb already had provisions of extra pins)
What models are these? I have two SU-X101's, do they have non-identical components inside? Hopefully not, the "identical" cd-players are enough (SL-PJ28)...
They’re X101 amps - one had the fan (regional release)
What I changed on the fan cooled one was the following
Power Xfmr
Bridge Rectifier Diodes
Reservoir Caps
Power IC
Silver Power Switch
Added (pcb already had provisions)
Output Relay
Relay drive transistor
Resistors - Relay Power feed and transistor input and power feed to pin 2 of Power IC
Back emf diode for relay
Capacitors associated w/ pins 1 & 17 of power IC
Extra new class A decal on front panel
I have bass problems from my turntable and therefore wanted a subsonic filter, rega makes one phonostage with subsonic filter (i use an external phono stage) and because it's something like £150 (didin't find anything used i would buy) i thought why not a new amp, than i could be lucky to get better sound when not playing lp's and not only fix some of the bass problems (excessive movements, new cartridge,turntable later if the is necessary).
Sansusi vintage technics SU 8080, technics SU-V85A and Technics SU-VX820
The SU-V85A has a power consumption of 750 watt (very high heat?) subsonic filter at 20hz is only -6db (not alot imho) 2x100 watt in 8 ohm, SU-VX820 uses only 320watt, the subsonic filter is 20db -12db/ pr octav which is alot better ;-) and 2x90 watt in 8ohm.
The SU-VX820 has some scratches but was serviced but a former panasonic technician (not at the factory, he just repaired panasonic/technics products for 10 years). The one i bought (get it next week), payied what equal to £200 with shipping
Is the SU-VX820 the newer version of the SU-VX700, about the same power but the SU-VX820 is slightly lighter, both models have a higher mode SU-VX800 and SU-VX920
Difference between the SU-VX700 and SU-VX820?
What can you else tell me about the Technics SU-VX820, i can't find any reviews of the amp and only a hand full of youtube videos, specs i have.
MOS class AA is MOS V. Amp so Mosfet is used in voltage amp, with BiPolar Current drive stage (V.amp and Current drive amp drive speaker via Wheatstone bridge)
haven’t had an 8600 (that was pre new class A)
I just mentioned it because i once had one and despite being able to get a SU-8080 i because of it's age didn't choose that amp
OK, I checked both of the little fuses near the relay and these are both good.
I was able to open the relay today after getting over my angst to do so... cleaned both of the contacts. It appears to operate just fine.
I found one solder pad connecting R375 to TH301 had lifted from the PCB, along with the components. I resoldered these two together, so I don't believe there is an issue here anymore. Guess that's why it's black under the resistor. I would say this is on the Left Channel.
I was then able to do some "Troubleshooting" as per the SU-V4a Service Manual, using my Fluke27. Hope I'm measuring it correctly (DC mV).
Clamp Voltage L channel TP301-TP303 (negative probe) was 0.7, was able to adjust it down to 0.5 as per the procedure. ICQ L channel then adjusted to the correct clamping voltage of 15.5. Both readings were relatively stable.
When checking the Right channel, there is no post on TP304, just a pad. Hope this is correct. Clamping voltage is all over the place, both negative and positive mV, doesn't matter where R338 is located. As such, there was no point in trying to adjust the ICQ, as it also all over the place.
Guess I have a bigger problem somewhere....
Can't figure out what the other TP 's are for as the "Manual" doesn't really go into these.
I also have a SU-V4A, that is losing power on one channel. I am just about to open it up. I would appreciate a link to the full service manual, as I can't find information on how to calibrate the amplifier.
I just acquired a SU-V4X "not working". Previous owner states it recently worked, but now stays in "safety mode". So my first look into it turned up a couple of obvious issues; one is a leaky Gold cap, didn't soak far into the circuit board, just around one lead on the bottom. The other is a lifted trace on the input board where the phono EQ board attaches, that's repairable. And missing the jumpers on the back panel. I haven't tried to power it up yet. Recently moved and my variac is still boxed up in storage. So have ordered the supercaps, a new relay (not worth cleaning when a new one is $6 from Mouser), and a few capacitors I didn't already have on hand. Used a magnifying glass to inspect the power module solder joints, the A1123 transistors, other areas in the power supply, and the ribbon cables. Nothing looks bad, but I'll reflow all those high current or high heat areas just in case. Already used Deoxit on the controls and switches.
One question if anyone knows: is it possible to get replacement bulbs for the Power On indicator? One has a broken filament and the other might be good, but I'd like to get new ones. And, are they special in any way for the circuit they are in, or just indicators? Anything else I should be looking closely at?
It will be nice to hear Baily's favorite New Class A amp when it's up and singing!
Niice goin
the bulbs are axial 12v 55mA Technics p/n XAMR74S17
V4X amps have 2 pcb runs what version is yours?
A type (17 printed next to last pin of SVI)
and B type (16 printed next to last pin of SVI)
