80's Technics Integrated Amps
Hehe niiice
I’ve had 2 that have had relay issues (lights stable no click) one was dry joints on coil side of relay, other was a break in the relay coil wire to its terminal…
As the jolt (though small) as the relay turns on takes effect on the joints over the years…. Atm have an X90 doing this trick… much more to dismantle to get to under the relay…
Either way not a hard or costly fix
and yes, Floyd sounds sublime on a V4X - love shine on you crazy diamond (well the whole wish you were here album) on them
I’ve recently acquired for a very good price a technics su 800 and su-v1x. The v1x sounds better through a spare pair of monitor Audio bronze 5s to my ears. However the “class A” lamp flickers slightly it doesn’t flash just if I look at it it’s obviously flickering at a high speed. Does this matter ?
Does this matter like it does on say the v505? Also I’ve seen a v4x on sale online but unsure how to tell which version it is before I try it out!
Thanks for your advice :) If I was to give you a serial number for a v4x, can you confirm if it's from the better of the two layouts? Have been offered one for a very good price and after reading this thread I want to try it
I know some of the date codes (most of them 1984 - can easily see the board type through vents in top - just look next to last pin on SVI
Sweet as :)
Nothing wrong with having spares! (Spesh since they’ll all soon be unobtanium)
You have a great setup... the V8 ought to be bulletproof now... I’d imagine only having to keep the input selectors clean.
I often wonder why the SE-A5 never got dual xfmrs like the V8...
Enjoy the bliss :)
Hi Baily!
It's been a long time. Lots of changes and events over the years here. I hope you are well.
The totally refurbed V8 mentioned above finally came out of storage and I fired it up. Everything was fine and it sounded Great. Very impressed, phenomenal bass production. After an hour I hooked up a four ohm load (two sets of 8ohm Klipsch 280s) and again great sound great bass. Just as I was regretting not having heard this amp since it's total refurb in 2018 the machine shut down. It was pretty warm, but then these are known for running hot. 2 of the 3 fuses were blown and several of the "Sanken" outputs tested blown. I've recently come to find out that genuine Sanken 1494/3858s weigh 18.2 grams each. My entire batch, including the ones that were installed in the V8 weigh 12.4 to 13.6 grams. They are bogus.
I had also purchased 10 pieces of Sanken 1187/2838s back then for much higher prices. I thought I had been ripped off. But, it turns out those 1187s weigh 18.3 grams each, no variance. I think they are genuine.
My question Baily, are those 1187s OK to install in the V8? You had mentioned previously that they spec'd out very similar to stock V6/V8 outputs but mentioned the higher frequency of the 1187s. Is that a problem for the V8s? Any danger of oscillation?
I thank you for all your help and advice over the years. Where would us '80s Technics Integrated amp lovers be without you?
Best Regards from Texas
Hi Baily!
Thank you Baily! I'm glad you're OK.
So it is no problem to install them in the SV8, right? The fact that they are faster ft is not a problem?
Kind Regards,
Me again for an update :)
I moved at the beginning of last year and had to move some stuff around.
I had my dad's set (SU-C04, ST-C03, RS-M02, SL-DL5), and the SU-V95 in storage, meanwhile in my living room the SU-V5, SH-8025, ST-Z1 paired to a couple SB-F2 and SB-K915 were used for casual listening :)
After a while I also wanted something smaller for my office, where I actually spend most of my day. One day wondering in marketplace I saw the 04 set of Micro Series components, I couldn't pass that up!
Unfortunately the amp was in bad shape, so I went to get my dad's set, thinking I would be able to use parts from the newly aquired one to fix the other one.
But no dice, somebody had been into the amp and the original driver and power transistors were long gone, so I had 2 amps and neither worked as they should.
I saw yet another amp!.. So I bought it for parts, the thing is, even though the fascia was rather rough, the internals were perfect, nobody had ever disassembled it.
So I decided to try and fix all 3, some research here in AK, scoured through ebay looking for NOS transistors, mouser for the rest of the parts, and luckily found NOS 2SB688 and 2SD718.
After a lot of work and a recap, all three amps were working perfect! (I even upgraded some stuff "while I was in there")
They really sound nice now!
Also had to fix my dad's deck, had a couple blown transistors which drove solenoids, and with that both sets were (mostly) working correctly!
After that I only had some SB-F2 speakers, so bought another pair of SB-F2s (to fix a broken tweeter... again, ended up fixing both sets), and a couple SB-F1MK2s, the latter ones I bought because it was father's day and I wanted to return my dad's set to him with a couple speakers at least.
As I now had 2 amps, I needed yet another set of speakers (I returned one SB-F2 set over to the living room), I've always been curious about the PolkAudio T15, so bought a pair.
Unfortunately my dad's ST-C03 tuner had some issues I wasn't able to resolve, tracked them to a uC, but was unable to source one, saw another ST-C03 on ebay, bought it and damn it had the same issue! So bought a ST-C01 for me, and I gave my ST-C04 to my dad
This revealed a small problem of not using a single amp with main and remote outputs.. I have 2 volumes (I know, first world problem haha), so one day I saw a SU-C01, SE-C01 ("blown") and ST-C01 set on marketplace for a very good price.
Bought it thinking the SU-C04 would be nice, the ST-C01 would be a backup in case mine or my dad tuner's quit and curious if I would be able to fix the amp.
So now looking into fixing the amp, meanwhile the stack at the office is higher lol
I have recently acquired a technics su-v5. It’s currently feeding some wharfedale lintons and sounds decent
They’re X101 amps - one had the fan (regional release)
What I changed on the fan cooled one was the following
Power Xfmr
Bridge Rectifier Diodes
Reservoir Caps
Power IC
Silver Power Switch
Added (pcb already had provisions)
Output Relay
Relay drive transistor
Resistors - Relay Power feed and transistor input and power feed to pin 2 of Power IC
Back emf diode for relay
Capacitors associated w/ pins 1 & 17 of power IC
Extra new class A decal on front panel
hi! sorry to bring up and old post, but I own an x301 amp and was looking at upgrading it further. to this moment I upgraded the opamps (huge difference) and the reservoir caps. so my questions are:
which of your modifications made the most difference?
is the SVI3206 a drop in replacement or what extra mods must be made?
is there any point to look for a non BC 310x module? instead of SVI3206
it would be really nice if you could specify the parts used.
not much of a tech guy, i just own an iron and know how to use google )
any of the 18 pin SVI3100, SVI3200 series will fit nicely. The centre 14 pins on all have same pinout/function The heatink has bolt pattern for it,
Running SVI3104 / 3204 WITH larger reservoir caps and bridge rectifier will se you comfy on 4 ohm too on standard xfmr (on fan equipped variants)
To get the the extra power - you’ll want to up the power xfmr, reservoir caps and rectifier diodes
Relay 24VDC SSY134
drive transistor 2SA992 (emitter gnd, collector to relay, base to power ic)
control feed resistor (pin 18 to relay transistor) 22K
2x MA4120 (back emf suppressors)
Resistors from -B to relay 3x 680 ohm 1/2W (in series)
the PCB has the the holes for these.
(Relay power feed resistors connect to the 2 points highlighted in pic)
Relay 24VDC SSY134
just half an hour before you replied i could no longer wait and ordered the 3104 (seems to be non BC), since i wasn't sure the thin heatsink would handle the 3105. I do have the fan though (even serviced it)
so what I have left to buy is the bridge rectifier. any recommendations?
Some amazing pictures! How does the cu-04 compare to say the su-v4x? I am in need of a small unit for a project
Relay 24VDC SSY134
hello again. so the svi3104 got delivered and this is what I did:
something is obviously wrong, because when I turned up the unit in a short while the pin 17 capacitor gave a smoke and then combusted (perhaps the smoke was from a different part, but not likely)
before and after the combustion there was no sound (at least in headphones) - not even static hiss, only power on/off clicks (volume level had also no effect), the only thing that changed is that the fan started spinning at full as if the amp was under maximum load or the in-out ext pins were disconnected
the relay clicks immediately after powering on and several seconds after powering off.
I used HER508 for the bridge rectifier and 10 000 caps
P.S.
I understand that the monkey see - monkey do approach is not to be respected by qualified members of the community, but I wouldn't have ordered the 3104 module if I haven't misread your messages and falsely assumed that this module was plug and play (as in the same 14 pins configuration). my fault completely
so please help me, kind sir, to get this over with, for my wife is nagging about there being no sound =0)
P.P.S.
i was not the one to decipher your instructions and come up with what's on that scheme, so could you please reply as if I was a kindergartner or an idiot =0)
P.P.S.
I'm attaching the datasheets of the parts used for your convenience
