919 mc head-amp
ghamilton
Any 919 owners using the MC section of your phono stage? I'd like to hear some comments about what you think of its performance.
It is not DC. The AU-X1 is DC.
Years ago when I used my AU-919 with a Fidelity Research FR1 - Mk2 MC cartridge I had problems with low volume because the input impedance of the MC head amp in the AU-919 is very low in the order of 10 ohms which is too low for most MC cartridges :(
I remember doing a bit of a kludge to improve things by removing the 33 ohm resistors in the gate circuit in order to increase the input impedance which helped a bit. It's a bit of a kludge which relies on the cartridge to provide the DC return path for the circuit. You could probably replace it with a higher value resistor but the head amp is a bit limited in this way.
