QSilver
I got one an A-60 pretty cheap the other day, a bit ruffed up but salvagable. I think it has been a little wet at some stage as there is a bit of rust and some resistors were rusting on their legs. I've replaced the bad looking resistors and powered it on with DBT. All is well and the DBT goes dim, but the protection relay doesn't click in. Measuring the coil pins, I have +35VDC on both sides of the coil so the protection circuit isn't letting the relay come on.
I checked the DC offset and it was around 3mV or lower on both channels. I removed the output transistors to get better access to some of the resistors etc and tried agian without them in and still the protection circuit doesn't come on.
I took some readings around the circuit as best I can. I found the schematic but the X-Ray schematic is quite poor and I cant make out most of the writing so I'm following traces.
I took some measurements on Q706 which looks to operate the relay, and around D708 which is a Zener. Either side of R718, I have +35V, and then around 0.2V where I should have 13.5... or 15.5... I can't make it out so well on the schematic... I have 0V between the zener and Q706.
Is this working correctly and I need to looks somewhere else? I can't see a reason why protection let the relay engage but maybe I'm missing something?
