Lavane
Lunatic Member
Then it must be the low gain version.Afaik, standard (low) gain is the default version, because most users couple them to active line stages.
12AU7s, standard gain version.Then it must be the low gain version.
Does your version use the 12AU7's or 12AT7's?Whatever he is shipping in the kits now. I never thought to ask.
Its the 12AU7 version.Does your version use the 12AU7's or 12AT7's?
I just read through the paper work and nothing about what tap to use when running two or four tubes.
I will be running a quad instead of just two, but ya, it doesn't make sense. Here is the schematic sent with the instructions.hm, that doesn't really make sense to me. Everything I know about parallel tubes (which is limited, admittedly) is that they want half the plate load as non-parallel, so if this is 4k plate to plate for single, 2k plate to plate for parallel makes sense.
They will be the biggest tube amps I've ever had. The one in my avatar is only 5.5wpc. The best sounding preamp I've ever had is the Erhard's Ella. I really like it. I've had several TOTL 70's Marantz SS systems, but have sold most of it.Can't wait to hear it compared to your avatar pic , wow many more watts nice!
What do you think is the highest end thing you own? I know you own other stuff. It will be interesting how this compares either way.
The autobias boardss are no longer sold by VTA. Too many failures of the board. One person even added a regulator board connected to the autobias board.My M125's see a lot of use, typically 8-12 hours per day. They really are a joy to listen to. What I found took them to the next level for me was incorporating autobiasing modules. Most significantly in terms of improved stability. Rectifiers esp are pushed really hard in these amps. Why you so often see SS rectification being recommended for use in these, as most modern tube rectifiers will simply go pop in these amps. Something you learn fast if you don't know otherwise, as in my case. Lost my first tube rectifier within 2 weeks. So good move on the part of the OP to go SS right off the bat.
Another issue I had with the stock build, maybe twice a year on average, was power tubes red plating. Infrequent enough not to pose a major headache, but definitely not liking impact on my tubing expenditures! Fortunately this is no longer an issue, as post AB has seen a total cessation of red plate events or rectifier arcing going on almost two years now. Plus its really nice now not having to futz with manual bias trim pots. (removed during this upgrade) Plus I like the little leds that inform whether the tubes have biased up properly post startup, nice feature. Getting way more hours out of my tubes now, so in time this mod actually pays for itself.
For tube complement running KT120, RCA clear tops for driver tubes, and gZ37 tube rectifier. Splendid results for SQ.
Quite possible my experiences are a non issue with latest kits or were self inflicted due to sloppy workmanship on my part. Above is just fyi should any similar quirkiness ensue, and what I did to resolve. Have fun and enjoy these great amps!
It shows a rectifier tube in the schematic, but lists a WZ68 SS rectifier. I have a couple of the WZ68's. I think I'm going to remove the copper top and drill some holes near the bottom and top to get a bit of air flow. They do run hot. Man I wish a tube company would produce GZ37 rectifiers. You would think there would be enough demand.That is a whole lot to ask out of a single rectifier tube. Quick look at the datasheet tells me thats going to want more than double what a 5ar4 can provide at full power, and most of what it can provide just at idle. This really needs to be solid state rectified.
I remember you having that red plate issueMostly apples to early version of the board. Has since been updated and incorporates a number of fixes. One of the more significant changes was the addition of an on board isolation transformer. I waited for the newer version to be released as was aware of the issues with the original board. Per my post the updated board has been trouble free.
Current SOS is below (no affiliation). On their website they indicate they are exclusive NA agent for these. I rather suspect this is a larger factor in why VTA no longer offer this product.
https://www.erhard-audio.com/
Multiple people gave you specific instructions on how to diagnose and fix it, which you ignored in favor of a band aid which doesn't work, cant work, (auto bias board)
Reason for that is that the tech who installed the boards found and fixed the fault.
That's what techs do.
Pull a transmission out of a truck and find a broken flex plate, you are going to replace both the trans and the flex plate.
When you hired the tech to install those boards he would have been remiss if he didn't check all the things we told you to check.
No doubt he found the fault, and also, the customer is always right. I feel 100% confident saying those boards didn't fix your amp. They had nothing to do with it.
The Tech fixed your amp.
He had to do that, likely for free, understanding the work you requested he do, was not going to be effective unless he made the repair.
Now back to your regularly scheduled programming.
